07-21-2018, 02:47 PM
Rockwood front and rear doors keyed alike?
I have a 2014 2502S mini lite. Front door lock and deadbolt open/close fine. But, when trying the same key, it goes in fine , but won't turn. I've lubed the locks, but still won't turn. Any advise would be appreciated.
07-21-2018, 02:52 PM
Check you key numbers. Many TT have different keying for the front and rear doors. My Microlite has different keying: front and back doors.
Larry WB4WSA
2017 Microlite 25KS
2006 F350 SD CC 6.0
07-21-2018, 05:23 PM
Two keys on the 2604ws. One of the reasons I went to a RVLock.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
07-21-2018, 05:29 PM
My rig with two doors has two keys, its called assembly line for speed.
Retired Navy
2016 Flagstaff 26 FKWS
07-21-2018, 08:30 PM
My Mini Lite had front and rear keyed differently. I picked one and got a new matching lock for the other one.
http://www.rvlocksandmore.com/
2011 Traverse LT, 3.6L, FWD
07-21-2018, 08:52 PM
Took me a few tries to figure it out, but YES, we have two sets if keys, one for the front door and one for the back door.
07-21-2018, 09:16 PM
When I had my PDI, the dealer wrapped some tape around one of the keys so you could tell them apart. But you still had to carry two keys. Single key is a LOT easier.
07-22-2018, 09:00 AM
our front and rear doors were keyed differently. get the lock / key code from the lock that works and then order a new lock with the same key code for the other door. we used rvlocksandmore.com but there are other places on-line. not hard at all to replace the lock.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
07-22-2018, 01:32 PM
If you have two keys and one breaks you can still get into the other door. Seems like a good design on this part.
B and B
07-22-2018, 02:14 PM
And...
And if you have two keys alike and one breaks, you can use the other one to get into both doors.
Larry
07-22-2018, 05:43 PM
Larry
You also have 4 keys, not just 2!
07-22-2018, 06:03 PM
A locksmith can fix this.
Plan 2 order two new key ways that are the same number as the other door.
Youtube will show you how to make a majic key. You file one of the old keys in a spot. When you put the old key that you made majic, in the key way that is unlocked, the key way come out. You then push the new key way in the old hole.
07-23-2018, 12:09 PM
locks
I have 5 keyed doors or storage, all different keys.
08-30-2018, 01:31 PM
Problem solved
Took rear door latch apart from inside, there was a sticker with the key code #, found them on eBay new two for $9.95
09-03-2018, 08:19 PM
Originally Posted by rockfordroo
How did you order a lock with a specific key code?
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
09-03-2018, 09:56 PM
Your key and lock should have a code on it. You can order a lock with the same code here:
RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys
09-08-2018, 02:41 PM
Thanks to your info, I ordered, received, and installed a new lock on one of my doors.
If anyone needs a lock with "G383" key code let me know. I have a spare I'll sell cheap.
2019 Rockwood 2503s
