Old 07-05-2012, 01:17 PM   #1
mike54's Avatar
Unhappy rockwood is falling apart
our one year old Rockwood ultra signature lite 8319 is falling apart.
closet pole was only screwed into thin paneling no backing I could find
entertainment door screws pulling out
all the ceiling vents fell apart the third camping trip last year
microwave inside peeling and rusty
door closure screws pulled out this morning
I hate the water filter location and want it bypassed or removed.
so far no big problems like slides failing, wheels falling off, awning not working
most I'll fix myself but why should I have to? I can't wait until the FROG rally I hope they have guys from the factory come listen to the problems everyone seems to be having.
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 07-06-2012, 05:43 PM   #2
Is it still under warranty? I would have them fix it. Did you get the second year warranty also?
Wumba is offline   Reply With Quote
Old 07-10-2012, 03:13 AM   #3
HogHead
Bauerson's Avatar
Yeah, sorry to hear it also. I dont hang or attach anything without first having a solid foundation. But i had problems with the tail light blowing fuses in my suburban. Then when the light s were on and i actuated the brakes they overbraked it was a horrible event on a rainy night coming back from tahoe. Luckily still under warranty and we found the problem. Ofcourse in the furthest corner of the trailer, under the shower pan. Someone screwed the wire and caused a short in the whole electrical / lighting system. I guess it could have caused a fire. The tech yanked the wire and pulled out one of the marker lights. Whew! We are good to go now. This problem took a while to manifest itself. Maybe because things shifted in the trailer or somthing.
Bauerson is offline   Reply With Quote
Old 07-10-2012, 06:00 AM   #4
I don't want to say this and I hope I am wrong in your case but it might not be over. I had more problems with the structure two weeks after the warrenty was up and it continued, the appliances where good except the 13,500 BTU Dometic a/c unit, I change it out and installed a Carrier 15,000 BTU unit. My camper was an 8314ss, this rig needs a 15K as standard not a 13.5K....
Old 07-10-2012, 07:14 AM   #5
Yes you did have structural problems after the warrenty was up,you said a Tree fell on your unit. May your unit RIP at the junkyard,as you said. Youroo!!
Old 07-15-2012, 05:25 PM   #6
I am disgusted with the workmanship in my 2011 Rockwood 1809. Can this really be the work of Americans? Sadly, it is. My travel trailer shows an astonishing lack of care in its assembly. I realize that to have an ultralight trailer there must be some sacrifice in the weight of components but there is no excuse for those components being assembled so unprofessionally.
My AC leaked when it rained. I took the bottom cover off and looked at the four long screws/bolts which connect the inside with the outside (with a gasket in between). There was a total of over 3 inches of thread showing on the four screws! By simply screwing the screws in, as the assemblers should have done, I stopped the leak.
I just found a screw behind the stove that had been broken off BEFORE it was inserted - there was a 1/16" dimple in the wood under the panel with no broken off screw shank. Unbelievable!
There are many more examples of absolutely astonishing disregard for standard building practices in my trailer. Would I ever buy another Rockwood Product? Would I ever buy another Forest River Product? Would I ever hesitate to warn friends, family, acquaintances, complete strangers, about buying from this company? What do you think?
ProfessorB is offline   Reply With Quote
Old 07-15-2012, 05:41 PM   #7
Hob
mike54,
Tell this to herk7769 under the thread, "I love my Forest River Product." I think he bought stock in Forest River. He is a fantastic help with problems. Yet, the way he sometimes gets on the Forest River podium you need to wonder why he is there with all the help promoting Forest River.
Hob is offline   Reply With Quote
Old 07-15-2012, 06:02 PM   #8
Too old to be too smart
SpringerPop's Avatar
Don't you think that's a little unfair to Herk?
He's had good luck with his, and he's satisfied with it.
I believe he genuinely wants to help, and I have never detected any "hidden agendas" in his posts.
Some folks are just like that, and not everybody is self-serving alone, thank goodness!
Pop
2004 Terry 250RKS, perfect for the two of us and the pups. It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3:73's
SpringerPop is offline   Reply With Quote
Old 07-15-2012, 06:34 PM   #9
I find it interesting that both the Rockwood and the Forest River websites have no contact info. That is a very informative fact. They clearly have no use for feedback. They take your money and then you're on your own!
Old 07-15-2012, 06:45 PM   #10
Wanna Be Camper
SaskCampers's Avatar
You may not want to buy from very many RV manufacturers then as more than FR build units the way our FR units are made and some of them are in the 6 figure range. My BIL has a unit made by K-Z and anything I can see wrong with my FR made unit he can find pretty much the same standard of build and QC on his.
A wise man once said "The grass is not always greener on the other side".
And BTW I agree that Herk is just a happy camper as are we. Sure we have had some minor issues but all has been looked after very well by our dealer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2013: 16 2014: 5 2015: 3
