Old 04-06-2014, 11:03 AM   #1
Rockwood mini lite 2306
Hi all,
Was wondering if someone could help me out. Im looking to purchase one and get the hensley cub but i need the height from the ground to top of hitch ball so that i can order the right drop bar. If anyone can help out that would be much appreciated.
Kevin
kevin1977 is offline   Reply With Quote
Old 04-09-2014, 09:45 AM   #2
KDHfan's Avatar
Originally Posted by kevin1977 View Post
Hi all,
Kevin
Hey Kevin... Do you still need that measurement? Heading to the camper this afternoon and will tape it for you.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-09-2014, 11:10 AM   #3
KDHfan That would be great if you could help me out with that if you dont mind the trouble.
Kevin
Old 04-09-2014, 05:13 PM   #4
If i remember correctly mine was 20 3/4. I can double check when i get home though. If KDH hasnt beat me to it.
Iamstik81 is offline   Reply With Quote
Old 04-09-2014, 05:47 PM   #5
thanks guys that would be great especially if they both match
Old 04-09-2014, 08:36 PM   #6
KDHfan's Avatar
Sitting level... I have it at 23-1/2" to the top of where the hitch ball sits.
Old 04-09-2014, 10:28 PM   #7
Thank you very much
Old 04-09-2014, 10:30 PM   #8
KDH if you dont mind what hitch do you have? I leaning towards the cub because of the short wheel base of the diesel cherokee but being my first full size tt not sure if its needed.
Old 04-10-2014, 01:02 PM   #9
KDHfan's Avatar
Just so we're clear... You wanted me to measure the 2306 tongue height, correct? I think the ball height as it sits on a vehicle will vary slightly depending on the vehicle itself and who/how it was installed/set up... Correct? The WD system will also cause variation.
I have the Equalizer 4-point... For me, a more expensive, "better" system would be a waste of my money, as I have had no issues with sway since installing it. And the kicker for me to go with the equalizer over some of the others was that you can hook up easily even if you have to back in at an angle.
Old 04-10-2014, 01:15 PM   #10
Indymule's Avatar
Hey Kevin,
I have a Flagstaff 23lb and I have a Hensley cub hitch. We originally towed this with a Nissan Pathfinder. The cub hitch is great, I would buy another one in a heartbeat.
Terry at Hensley hitch can get you setup with the right drawbar. I think mine is a 2 inch drop. I did add airbags to the pathfinder to help stiffen the suspension when towing.
I still have the pathfinder but I also have a F150 and that is what I tow with most of the time. The pathfinder can tow this trailer but it works hard. The armada should tow this great little trailer just fine.
Enjoy the camper and in my opinion, the hensley hitch is worth the extra money.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 04-10-2014, 01:18 PM   #11
Indymule's Avatar
Here is a pic with the camper hooked up to the Pathfinder.
Ham Callsign K9NDY
Old 04-10-2014, 01:32 PM   #12
KDH yes thats what i wanted. i needed to figure out the bar drop that i need for the hitch. I'm not to sure what the difference between the pathfinder armada and the jeep are but will not be getting a new TV so i hope i will be served well with the Cherokee diesel. I think it has a bit more torque than the pathfinder but the wheel base is smaller than the armada.
Old 04-10-2014, 07:51 PM   #13
KDHfan's Avatar
Kevin... My Armada has a 5.6 in it and has a 6500lb tow capacity... it has plenty of power to pull the 2306... Wish my suspension was a little stiffer, however. I'll be working on that in the near future (LT tires and possibly air bags)... I'm a "soccer Dad" so a truck is not in the cards for me.
I honestly think if you go with one of better sway bars, you should be fine even with the shorter wheel base.
Old 04-10-2014, 11:47 PM   #14
Ya i think my suspension will be on the soft side. Think it will be on my upgrade list one day. Just need to buy one next.
2306, rockwood
