Old 08-21-2019, 10:39 AM   #1
Rockwood Mini Lite AC issue
Hello! We have a Rockwood Mini Lite 2304 with a Coleman Mach AC. We're having a wickedly hot & humid spell in the NE - and we're suffering in our RV.
Here's the situation: on Low Cool, and the right knob turned halfway to the coolest setting, it begins to work - lowering the humidity a bit, then just blows cool air, with the humidity indoors steadily rising. If I turn the knob all the way to the coolest, immediately it starts taking the humidity down...for about 5 minutes; then, again, the humidity goes back up. The last couple of days the humidity outdoors is around 85% - inside 88%!
When we use High Cool, the same thing happens - but we get frozen out. The temp goes down to 67-68, with the humidity soaring inside. We're totally confused because it shouldn't be blowing cold, humid air - it should be DRYING the air as well. If seems that it should not be cooling the air either, but it is.
Any ideas? Is it freezing up? Thanks in advance for your advice!
mlleelise is offline   Reply With Quote
Old 08-21-2019, 10:48 AM   #2
Sounds like it's freezing up. There's a freeze sensor somewhere on the evaporator. It may have shifted or fallen off. Also, keep the fan on high.
Low freon can also cause freezing. If that's the case, you'll probably need a new one, as these AC units are not built for recharging.
2011 Traverse LT, 3.6L, FWD
Old 08-21-2019, 11:38 AM   #3
When you say "Keep the fan on high," do you mean on "High Cool" or "High Fan"? High fan only is pushing in outside air, right?
It sounds like we should not run it on Low Cool until we find out if the sensor is bad or the freon is low.
Old 08-21-2019, 03:47 PM   #4
Don't know your specific unit, but I highly doubt that either position brings in "outside air."
"High cool" is probably AC compressor providing cooling and circulating fan is on high speed. "High fan" is probably AC compressor NOT running, just the fan running on high to move air around.
I have a Coleman Mach, but it's ducted and runs off a thermostat, not from switches on the unit. In fact, I have pics of a 2304, circa Jan 2015, that has ducted AC, hence it's operated by a thermostat on the wall. So I"m not sure what you mean by "turning the knob."
My thermostat looked like this one, only black:
Name:   Analog Coleman-Mach.jpg
Mine does not pull in any "outside air." I'm not aware of any AC unit that does that.
Old 08-22-2019, 01:57 PM   #5
rlh1957's Avatar
You do have your windows and roof vents closed I assume. If you have any condensation forming on roof vent or around window you can crack open a roof vent or window and see if that helps that.
Running the fan on high helps to circulate the air better and help the cooling efficiency. If you are getting a temp of 67-68 degrees with these units on hot and humid day, I say WOW.
The temperature coming down and then humidity climbing sounds like the compressor is shutting down or the air flow is becoming restricted because it is freezing up. Do you notice an air flow decrease then this is happening?
I am thinking this is low Freon or maybe other compressor issues. Might be as simple as the temperature probe coming off the evaporator coils.
Unscrew and totally remove the unit on your ceiling and look for a metal tube looking thing that attaches to the fins. You can even remove the cover during operation and maybe even see the freeze up. Does your unit have the ducted air or just the ceiling mounted unit?
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 08-22-2019, 04:43 PM   #6
It is a ceiling unit (see attached photo). No condensation on windows - Yes, it DOES cool it down beautifully, but everything inside is damp. The humidity makes everything feel wet.
Old 08-22-2019, 04:54 PM   #7
bikendan's Avatar
Ahhh, the old Blast from the Center non-ducted a/c.
Quite the noisemaker.
Equalizer WDH
Old 08-23-2019, 10:42 AM   #8
rlh1957's Avatar
You have a wall thermostat and a through the ceiling non ducted unit that has knobs for control on it? Are you sure that wall thermostat is connected? Seems odd for a wall mount and a chassis mounted control.
It is possible to drop the temperature and humidity still not be down where you want it. I was in a resort hotel in Jamaica and had the room at 71 degrees but the humidity just wouldn't come down. Every thing felt damp, I had request all new towels whether I used them or not everyday because they were damp the next day. It was more like a water chiller system than Freon evaporative AC. Just making a comparison.
Maybe others have an idea. Usually in our campers the temp never comes down that far without some humidity reduction.
24WS
FX4 Off Road (4X4)
Old 08-23-2019, 10:50 AM   #9
cavie's Avatar
I agree with post #8. This unit would not have a wall stat. I'll bet the wall stat is for the furnace. You running both at the same time? That would be my guess. A/C cooling to 67 degrees can not produce high humidity.
My house in Florida is set to cool to 84 while I'm gone for the summer. Humidity stays below 55%
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 08-23-2019, 11:33 AM   #10
OP never said he had wall mounted T-stat. I brought that up.
Old 08-23-2019, 09:01 PM   #11
There is no wall thermostat for the AC - only for the furnace, which is turned off. We would not be running the furnace AND the ac. We have an appt with the rv guy to come figure it out. Thanks for all the advice!
lite, mini lite, rockwood, rockwood mini lite
