Old 01-14-2018, 06:48 PM   #1
billkaz
Rockwood Mini Lite Slide Out Scraping Floor
One side of the slide out has sagged & ts ripping the linoleum. Anyone have info on how to fix the alignment, something I can do? Or who to contact for more info?
billkaz is offline   Reply With Quote
Old 01-14-2018, 08:03 PM   #2
bikendan's Avatar
What year and model of Rockwood do you have?
Your profile shows a 2004 Fleetwood Pioneer.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-14-2018, 08:52 PM   #3
billkaz
Current Model
Need to update profile
Now have 2015 2502s Mini Lite
Old 01-17-2018, 11:39 AM   #4
Hi, I do not have the exact same problem but I do have a slide out in my 2017 Georgetown GT3 that when all the way in rubs on the floor. I have noticed that the slide out is not plumb to the outside of the coach when all the way in. It tilts in at the top maybe 1/2" more than at the bottom. In fact, when driving it makes such a racket that I have taken to using a block of wood and a pry bar to lift it and then I stick a rubber door stop under the lowest part. That treats the symptoms. I thought that perhaps the gears were maybe off by a tooth or two but a friend who runs an RV repair facility showed me how the whole thing is a unit and you cant just tilt it to compensate for the rubbing. He called it a design flaw. Your case is more extreme but I can see where putting the slide motors under that kind of stress may lead to problems other than just the floor tile. I am sure that other owners have encountered the same problem. I wish that Forest River would do some kind of recall on it. Maybe an additional roller along the inside edge. Sorry I couldn't be more help. Regards
Retired Navy
2017 Georgetown GT3
Master Tow Dolly
dtougey is offline   Reply With Quote
Old 01-17-2018, 01:06 PM   #5
DMMILLER55's Avatar
See my past posts
We have 2502ks. See my past posts about our slideout nightmares. All fixed by FR at the factory and then tweaked repairs again at FROG RALLY. All good now but the journey was PAINFUL in so many ways!
DMMILLER55 is offline   Reply With Quote
Old 01-17-2018, 01:29 PM   #6
Had same problem on a Mini Lite 2304s
The nuts were loose on both sides underneath of the operating frame that carries the slide in and out. Slideout slickers will keep it from getting worse.
Fiddler Dan is offline   Reply With Quote
Old 01-17-2018, 02:16 PM   #7
OK, I'll bite. What are "slideout slickers?"
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 01-17-2018, 04:35 PM   #8
BUCKY2's Avatar
We had same problem with our FR wolf pup.Dealer ordered parts and fixed pronto. Including torn up upholstery fabric on the dinette base.
BUCKY2 is offline   Reply With Quote
Old 01-18-2018, 04:56 AM   #9
DouglasReid's Avatar
X2, Id love to know as well.
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 01-19-2018, 09:03 PM   #10
We were set to go pick up our new 2018 Rockwood 2104S tomorrow and received a call this evening from our sales person stating that during the PDI they closed the slide and it tore the Linoleum floor. After Reading this thread last night and that happening today I am now gun shy about the 2104 slide. We have since changed out mind and are buying a 2109S tomorrow instead.
I hope you guys get it figured out but it seems like a problem with the slide on that model.
Bissel is offline   Reply With Quote
floor, lite, rockwood, rockwood mini lite, slide, slide out
