Old 02-13-2015, 11:02 AM   #11
TURBS's Avatar
Originally Posted by psrujak View Post
The problem is that I would have to take the trailer 60 miles to the dealer and they would not be able to get it in the shop for two months. Forest River would only pay for the caulking and not a service call that was $250. So doing the caulking is not rocket science. I think I have the skills to do that. And NO youroo they will NOT PAY FOR IT.
The shop that couldn't get you in for two mo. Did you buy it there?
And youroo is absolutely right.
Had you took your camper to the dealer to perform the roof re-seal forest river would have paid 100% of the bill.
Forest river does not pay for service calls unless your broke down along the road.
Old 02-13-2015, 11:14 AM   #12
Witch Doctor's Avatar
Originally Posted by offroad View Post
We love ours, took delivery last September, and camped every weekend after including the first weekend in November.
After my wife saw the floor plan, everything else we looked at got compared to the 8329.
I think the two opposing slides and lack of overhead cabinets extending from a wall, make it very open feeling in the kitchen and living area. The entertainment center is in a perfect spot, and we like the room in the bedroom too. If we ever went back to a 5th wheel we really like the 8289WS, but not sure we'd want to give up the room the bedroom slide gives for the extra storage.
No leaks so far (fingers crossed) on ours, and I think the quality for an Ultra-Light is generally very good. The only issues with ours has been some scraping on the bottom of two of the slides, and a small fabric split in one of the window valance arms. Our dealer adjusted the slides and replaced the valance arm in under two weeks and I also had them swap the blue lights in the Renaissance fridge for white one's.
Mods so far
Battery charge connector - (Charge without hooking up shore power)
OC awning supports on main awning
4x - 5" fence posts for storage - (Next to the steps and between the slides)
120mm quiet fridge fans and improved air baffle
Swapped both thermostats for residential digital units
12V LCD voltage monitor panel
Deleted the factory water filter
Planned mods
Split the kitchen AC outlets on to a 2nd breaker
Dimmers for awning lights
Tongue storage box
Move the sub-woofer from under the sink (yes really) to entertainment area
Add 20amp input, and install 2nd island AC outlet for space heater when on 30A
Move low point drain valves inside (space dependent)
Just waiting for warmer weather now
believe it or not FR put my subwoofer under the entertainment center with no covers for the sound to come out. I had to cut in 2 speaker screens, one on each side. Much better. I swore I didn't have one. Made the dealer pull my fireplace to prove it was there. Another great FR design, just makes you scratch your head...
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 02-13-2015, 11:28 AM   #13
offroad's Avatar
We ordered without the fireplace to get a bit more storage, and use an infrared heater for fall and early spring camping. The units I'd seen online, had a screen mesh in one of the entertainment cabinet doors and the sub-woofer was behind that.
Under our sink is a panel you remove to get to the WH bypass, and behind that is where I found the sub. So yeah, ours is inside a closed cabinet too and buried behind that panel.
Will mod one of the entertainment cabinet doors and move it there.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 02-13-2015, 01:09 PM   #14
Very similar to the 3029W Windjammer we're considering. Love the opposing slides in back.
Happy trails,
billb800si is offline   Reply With Quote
Old 02-13-2015, 04:16 PM   #15
Wow I know the feeling I am new to the forum but old to towing (popup 1969) I have 2013 Sig ultra light 8289ws w/Dimond pkg. Its in for a new roof i.e. plywood and rubber.Had leaks at the front cap center vent and skylight. Still love the 5er.
I tug it along with a 2013 Silverado 2500 Crew Longbed gaser.
Bobster
2013 ROCKWOOD 8289WS
2013 Silverado 2500HD Crew/Longbed
rshultz is offline   Reply With Quote
Old 02-13-2015, 05:18 PM   #16
Fivealive's Avatar
How did you find the roof problem?
Fivealive is offline   Reply With Quote
Old 02-13-2015, 05:33 PM   #17
Hi Fivealive
Had water in the skylight,service center replacing skylight found soft wood
pulled back rubber roof and found damaged plywood in other areas.
Lucky for me insurance covering most of cost.
It never rains in California except on my 5th.
Bobster
Old 02-13-2015, 05:46 PM   #18
Yes
psrujak is offline   Reply With Quote
Old 02-13-2015, 06:39 PM   #19
5er_tom's Avatar
We had a 2013 8289WS. Ordered it new, and took delivery on 12/4/2012. We think it was a lemon, maybe a late Friday afternoon build. In 2 years we replaced both axles twice, had an entire new roof installed, replaced the refer condenser unit, and had the kitchen faucet fail. I believe they (FR and other manufacturers) cut too many corners to produce an ultra light for ½ ton truck towing. We put more miles on our unit in one year than many owner's do in several years. We put 30,000 miles on it in 2 years. We have traded the 8289WS for a new Wildcat that is not an ultra light.
Perhaps we are wrong in our assessment. Time will tell. We loved the Rockwood, but just could not continue considering the past history.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 02-13-2015, 07:13 PM   #20
our 8289 was also a 2012 build we have had no other problems except them great tires they put on.
Motor homed to Alaska twice and didn't get that much mileage.
Bobster
rockwood
