Old 01-26-2015, 02:22 PM   #31
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Indymule View Post
We have removed one of the chairs since my wife would prefer to sit on the sofa.
We did the same thing.
Before we removed one, my wife (who does the inside work) used to stack and lash down both of the chairs; the chairs aren't heavy.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-27-2015, 08:43 AM   #32
Cato's Avatar
We have removed one of the chairs since my wife would prefer to sit on the sofa. I have put felt pads on the feet of the chair and just slide it over by the door when the slide is in. There is room to slide the second chair in front of the door so you don't have to stack them. It does block the door but you can enter from the bedroom and still reach the panel.
We put the two chairs side by side in front of the door…fit perfectly. We use the bedroom door when slides not open…
Mostly pleased with the 2604ws…suggest you add an outlet in the bedroom..we had one added on the side of the "nightstand" (under the narrow closet…)
Also suggest create a breeze fan for all vents...
We are currently removing the "wallpaper" border….
(actually contact paper…yuck!) Brightens up the place. Where it was on the wall was very poor proportionally ….Looks much better, will post pics when all the glue removed…my suggestion is to order with out the border.
Good luck and safe travels
Cato is offline   Reply With Quote
Old 01-27-2015, 08:44 AM   #33
Cato's Avatar
forgot to mention we took out the mag rack with lamp...
Old 01-27-2015, 10:48 AM   #34
Cmccul's Avatar
Interested in the border removal. We ordered the Flagstaff 26 RLWS but my wife hates the border. WE didn't know you could order it without. Would like to hear how easily it comes off and see pictures.
[/SIGPIC]2015 Flagstaff 26RLWS Emerald
2014 Chevrolet 1500, 4 X 4, 5.3
73 nights in 2017
74 nights camped in 2016, 121 nights camped in 2015
Cmccul is offline   Reply With Quote
Old 01-27-2015, 11:14 AM   #35
Cato's Avatar
I never thought to ask about leaving the border off….
So, I started to remove it….was very disappointed to discover it is contact paper and not wall paper…(even more reason to remove it)
Heat it with a hair dryer and it will pull of relatively easily …. you may need to cut with razor knife at trim….removing is the easy part.
There will be adhesive residue…GooBeGone seemed to work the best…requires multiple applications…just keep wiping and rubbing, use small rags...I also used a plastic putty knife to scrape the excess adhesive as the GooBeGone softened it….
When the glue was all removed I cleaned the area with Dawn dish liquid.
It is so worth the effort….!
I will take some pics then figure out how to send them
Old 01-27-2015, 12:49 PM   #36
Cmccul's Avatar
Just curious when your camper was built. My wife was hoping to remove the border as soon as it arrives from the factory. She thought maybe if it's not on very long it will be easier to remove.
73 nights in 2017
Old 01-27-2015, 04:57 PM   #37
Cato's Avatar
The unit arrived in July 2014….it is a 2015…
This is our first outing so just getting used to where things belong and such…
AND getting rid of the border….the fact that it is contact paper makes it even more important to make it go way asap…
really brightens things up and makes it easier to decorate and make it your own!
Let me know how it goes!
Old 02-02-2015, 08:25 PM   #38
Cato's Avatar
all the border and the glue removed….
now we can begin to make this our own…
looks SO much better…
Old 02-02-2015, 10:25 PM   #39
Cmccul's Avatar
Looks great. Thanks for the pictures.
73 nights in 2017
Old 03-01-2015, 09:37 PM   #40
Cargo Weight
While on this model, does anyone know what the true cargo capacity is? Web and print says around 1500# but I have been reading that yellow sticker on units are now showing less than 800#. Also has anyone weighed yours loaded to see how much weight you are carrying in cargo?
okie joe is offline   Reply With Quote
2604, rockwood
