12-22-2013, 09:41 PM
Rockwood Water Filter systems
We just ordered a new Rockwood 8289 and was wondering what those of you with the factory installed water filters think of them, good, bad, or indifferent. We have always used an exterior water filter system and have been happy with that...no chance of leaks inside the compartment, but Rockwood doesn't give you a choice, the factory filter is standard equipment.
Rick
12-22-2013, 10:50 PM
Not Rockwood-
I had the dealer remove the filter from a cabinet and replace it with a piece of tubing.
I'll use a filter on the outside if I want to.
No way I'm going to lay on the floor and contort my way to the filter while risking spills and leaks twice a year!
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
12-23-2013, 12:01 AM
Owner/Operator
I bypassed the internal water filter on my 8289 because it was a pain to get to. Use a pair of external filters. Here's a link to the modification:
http://www.forestriverforums.com/for...ion-46104.html
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
12-23-2013, 07:11 AM
I want to see the water that is going into our unit before it (Contaminates) the water system. The (Blue) throwaway type are hard to see thru. Youroo!!
12-23-2013, 09:01 AM
Rodeo George....I also noticed a white PVC tube beside your water filter install, with what looks like a removeable cap. Is that a mod you made for sewer hose storage? And thanks for the detailed mod instructions.
Rick
12-23-2013, 09:03 AM
Twisty...on the 8289, the water filter is located outside, in the belly storage compartment so no contorting required.
Rick
12-23-2013, 12:32 PM
Owner/Operator
Rick
Yes it is the sewer hose carrier. Copied what was done by several other people here on the forum. Used 5" vinyl fence post (4-1/2" was not large enough), and a piece of vinyl rain gutter to slide in with the Rhino Flex hoses and sitting in the gutter. Works like a champ.
Rick
Rick, what year is your 8289? If it's a 2014, perhaps Rockwood finally listened to the owners and moved the water filter to a more accessible place. Mine is behind a panel in the understorage, and as I mentioned was a pain to get to because of having to remove the panel.
RodeoGeorge
12-23-2013, 01:29 PM
Yes, it is not easy to get to it. But, you only need to get in there to change it and/or to winterize. I still use mine as installed. The filter lasted about 60 days of camping. We may have hit some dirty water that plugged it up. When water pressure gets low, it might be the filter.
I do not plan to make any changes to mine, and I don't use an external filter. We normally don't drink campground water anyway. Also, I always ask if the campground water supply is city water or well water. If it is well water, I am sure to never add it to the water tank.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
12-23-2013, 07:32 PM
We have a Windjammer 3025 and what a pain in the butt the location of this filter is. After saying that, I must tell you that the only time I do anything with it is when I winterize. Now saying that, I must tell you, 'what a pain in the butt the location of this filter is'.
I may do what Youroo or Rodeo George did, or just eliminate it all together since we always drink bottled water. (Or in my case, bottled water, beer or Irish whiskey)
I use what ever comes out of the tap for coffee. Hey, if I can survive 2 weeks in Ontario's north woods, moose hunting, where we use lake water for coffee, cooking, showers and whatever, I can survive a long weekend camping.
A rainy day campin' is better than a sunny day workin'.
'13 Windjammer 3025W
'14 Ram 3500 w/6.7 Cummins
No dogs. No Cats. No kids. Just us.
12-23-2013, 09:54 PM
Rodeo George...mine is a 2014....and I am pretty sure it is still behind a panel. I know a few changes were made midway through the 2014 production and the toilet was moved so now the toilet drain pipe can be seen in the storage compartment whereas before it was hidden behind a panel wall, so not sure if that caused them to move the water filter. We'll see when the unit arrives.
5er-tom....are the replacement filters easy to find?
Rick
12-24-2013, 06:52 AM
the 2014 mini lite filter is in the front storage and fairly easy to get to.
12-26-2013, 12:23 AM
RodeoGeorge....just wondering how you attached the 5in PVC fence post to the underside of the 5er.
Rick
12-26-2013, 12:44 AM
Rick
I Took the whole thing out, they are hard to get to it is behind the outdoor shower for 1 above the water pump for 2 and behind the basement wall that is held in with 4 screws for 3. There is about 6 1/2" hoses that you have to work around. The filters are pretty expensive and I was told that you had to by them from the dealer. After taking it out I do not understand that it looks like any filter will work. It will cut down on your water pressure for sure. Now I just use a Camco external type. The high flow model with a pressure gauge attached. ....... My mode is keep it simple stupid, makes my life easier. Got that from my wife......
Coachmen M/H
Concord
2018 / 300 DSC
12-26-2013, 05:01 AM
Owner/Operator
Rick
On the 8289WS there is a vinyl boot or tray on each side inside the storage doors. If you remove those inserts you have access to the outside of the Frame I Beam.
I drilled up through the bottom, and through the outer lip of that I beam. Then used a long bolt, and some wood spacers between the Tube and the bottom of the RV, up through the frame lip. Put nylock nuts on the bolts, to guard against them coming loose with vibration.
I was familiar with the Frame I Beam lips, because when I installed the ULTRA FAB Eliminators (stabilizers) I also bolted through those lips.
If you look at the frame under one of the slide outs, you'll see the frame lip I'm referring to.
RodeoGeorge
12-26-2013, 10:16 AM
Question: Does the filter that comes with the RV, filter both the city water connection and water pump? It would be logical if they put it downstream of both, but logic sometimes seems to be optional equipment.
2014 Ford F250 Lariat
2014 Rockwood Signature Ultra Lite 8280 WS
2023 Forest River Rpod model 201
Louisiana before, fulltiming since April 11, 2014
blog--- www.gozatravels.blogspot.com
12-26-2013, 10:28 AM
Yes it is hooked up that way. But you are still filtering the hot water with the external filter before it go's into the tank.
Coachmen M/H
Concord
2018 / 300 DSC
12-26-2013, 11:27 AM
I used the Camco external ones with our previous trailer and was quite happy with them...just trying to figure out if I want to keep using them and do away with the factory install, which was the main reason I started the post...what I liked about the Camco filters was when we are home for a couple weeks between trips, I can put the Camco external filter in the fridge and its a hassle free task.
Rick
12-26-2013, 12:02 PM
Why won't you add well water to your fresh water tank?
Coachmen M/H
Concord
2018 / 300 DSC
12-26-2013, 02:12 PM
X2 ?
TURBS
merry christmas to everyone on FRF !
12-26-2013, 11:14 PM
We had a 2013, Rockwood Mini Lite. I learned at my first rally: remove the cartridge, use a Campco external filter! It allowed a better volume of water as well.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
