Old 12-22-2013, 08:41 PM   #1
WFD
Rockwood Water Filter systems
We just ordered a new Rockwood 8289 and was wondering what those of you with the factory installed water filters think of them, good, bad, or indifferent. We have always used an exterior water filter system and have been happy with that...no chance of leaks inside the compartment, but Rockwood doesn't give you a choice, the factory filter is standard equipment.
Rick
WFD is offline   Reply With Quote
Old 12-22-2013, 09:50 PM   #2
Twisty's Avatar
Not Rockwood-
I had the dealer remove the filter from a cabinet and replace it with a piece of tubing.
I'll use a filter on the outside if I want to.
No way I'm going to lay on the floor and contort my way to the filter while risking spills and leaks twice a year!
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 12-22-2013, 11:01 PM   #3
Owner/Operator
RodeoGeorge's Avatar
I bypassed the internal water filter on my 8289 because it was a pain to get to. Use a pair of external filters. Here's a link to the modification:
8289WS Water Filter Relocation
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 12-23-2013, 06:11 AM   #4
I want to see the water that is going into our unit before it (Contaminates) the water system. The (Blue) throwaway type are hard to see thru. Youroo!!
ID:	44073   Click image for larger version
ID:	44074   Click image for larger version
Old 12-23-2013, 08:01 AM   #5
WFD
Rodeo George....I also noticed a white PVC tube beside your water filter install, with what looks like a removeable cap. Is that a mod you made for sewer hose storage? And thanks for the detailed mod instructions.
Rick
Old 12-23-2013, 08:03 AM   #6
WFD
Twisty...on the 8289, the water filter is located outside, in the belly storage compartment so no contorting required.
Rick
Old 12-23-2013, 11:32 AM   #7
Owner/Operator
Rick
Yes it is the sewer hose carrier. Copied what was done by several other people here on the forum. Used 5" vinyl fence post (4-1/2" was not large enough), and a piece of vinyl rain gutter to slide in with the Rhino Flex hoses and sitting in the gutter. Works like a champ.
Rick
Rick, what year is your 8289? If it's a 2014, perhaps Rockwood finally listened to the owners and moved the water filter to a more accessible place. Mine is behind a panel in the understorage, and as I mentioned was a pain to get to because of having to remove the panel.
RodeoGeorge
Old 12-23-2013, 12:29 PM   #8
5er_tom's Avatar
Yes, it is not easy to get to it. But, you only need to get in there to change it and/or to winterize. I still use mine as installed. The filter lasted about 60 days of camping. We may have hit some dirty water that plugged it up. When water pressure gets low, it might be the filter.
I do not plan to make any changes to mine, and I don't use an external filter. We normally don't drink campground water anyway. Also, I always ask if the campground water supply is city water or well water. If it is well water, I am sure to never add it to the water tank.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 12-23-2013, 06:32 PM   #9
Whitewolf's Avatar
We have a Windjammer 3025 and what a pain in the butt the location of this filter is. After saying that, I must tell you that the only time I do anything with it is when I winterize. Now saying that, I must tell you, 'what a pain in the butt the location of this filter is'.
I may do what Youroo or Rodeo George did, or just eliminate it all together since we always drink bottled water. (Or in my case, bottled water, beer or Irish whiskey)
I use what ever comes out of the tap for coffee. Hey, if I can survive 2 weeks in Ontario's north woods, moose hunting, where we use lake water for coffee, cooking, showers and whatever, I can survive a long weekend camping.
A rainy day campin' is better than a sunny day workin'.
'13 Windjammer 3025W
'14 Ram 3500 w/6.7 Cummins
No dogs. No Cats. No kids. Just us.
Whitewolf is offline   Reply With Quote
Old 12-23-2013, 08:54 PM   #10
WFD
Rodeo George...mine is a 2014....and I am pretty sure it is still behind a panel. I know a few changes were made midway through the 2014 production and the toilet was moved so now the toilet drain pipe can be seen in the storage compartment whereas before it was hidden behind a panel wall, so not sure if that caused them to move the water filter. We'll see when the unit arrives.
5er-tom....are the replacement filters easy to find?
Rick
rockwood, water, water filter
