Old 09-06-2016, 09:59 AM   #1
Christ follower
Roof blistering and seam seal question
Bought our 2016 8329SS in February this year. Went up on the roof this weekend to check things out after finding a bunch of water on our floor. Found several bubbles on the roof and numerous large crack in the seam seal.
Is the blistering look on the roof normal? I wouldn't think so and hope it is under warranty.
I know the seam seal requires periodic maintenance but isn't this kinda quick for a unit that is 7 month old?
2016 Rockwood 8329SS
2003 Ford Excursion 4x4 7.3
Mount Pleasant, SC
"I can do all things through Christ who gives me strength." Ephesians 4:13
7.3Excursion4x4 is offline   Reply With Quote
Old 09-06-2016, 10:10 AM   #2
crunchman12001's Avatar
Hi,
If you are able to post a picture of the problem areas, we can tell you the best way to repair it.
2017 Salem Villa Estate 395RET-Coming soon
2015 F-250 FX4 SUPER DUTY 6.2L Gas 4WD SuperCab XL 3.73 rear / 158" WB / 8' bed. Factory anti-sway and brake controller
Old 09-06-2016, 10:19 AM   #3
jeff
jeff64's Avatar
Haven't had any leaks that I've noticed yet, but did see some bubbling and issues around the normal areas that necessitated a proactive approach and a tube of the self leveling sealer. Since it was the almond color and a Alpha Sys TPO roof I went for their sealant from CW. I wasn't real crazy about the flow/ cured appearance of their product compare with my previous experience with Dicor self leveling sealant. TT new in May 2015
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-08-2016, 04:53 PM   #4
Christ follower
Originally Posted by crunchman12001 View Post
Hi,
Here is a picture of the air bubbles under the roof.
Mount Pleasant, SC
Old 09-08-2016, 05:10 PM   #5
I would not worry about the bubbles unless they continue to grow. The seams require inspection after every trip.
Old 09-08-2016, 05:18 PM   #6
Flybob's Avatar
The rubber membrane is glued to the roof. There can be some areas that did not get adequate glue coverage. When the roof heats up the air under the membrane will expand and create bubbles. The membrane is still intact. The seams should be regularly checked and repaired ans needed.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
roo, roof
