Old 04-15-2016, 05:06 PM   #1
Roof Damage
I damaged my TPO roof last fall by snagging it on a grain probe. (You farmers can imagine how.) After contacting Alpha and buying the roof repair kit, I sealed the tear down with a heat gun and roller, cutting the stretched parts out so the membrane would lay flat. Using the recommended Scotch 77 adhesive, I applied the patch to cover the damaged area. I used the Alpha supplied, self leveling caulk around the patch as recommended, Everything was fine on the 1500 mile snowbird trip. On the return trip, the winds were terrible and when we got home, the patch was gone and the wind had loosened up where the torn fabric had been re-attached. See attached picture. The dealer says the only way to fix this is to replace the whole roof membrane for $6000! And, they don't like doing this job as it's difficult and very time consuming. I'm open to suggestions. Again, this is a tan, TPO roof, not a rubber roof membrane.
robertew is offline   Reply With Quote
Old 04-15-2016, 05:29 PM   #2
I would think eternabond would work.
https://www.eternabond.com/articles.asp?id=144
The dealer just wants to take your money!!
Hoser2eh is offline   Reply With Quote
Old 04-15-2016, 05:30 PM   #3
No wind will ever tear off eternabond
beachcamper is offline   Reply With Quote
Old 04-15-2016, 05:31 PM   #4
Ford Idaho's Avatar
If I may suggest.
http://www.googleadservices.com/page...FEB23D4EF3ACB0
Remove what remains of the first patch.
It will stick, be sure to follow the directions and roll it hard.
Old 04-15-2016, 05:47 PM   #5
Thanks for the suggestions. The patch was totally removed by the wind. I wish eternabond was available in something besides white. I don't think it will look very good on the leading edge of this tan roof. I suppose, also, that the loose existing membrane should be cut off.
Old 04-15-2016, 06:00 PM   #6
Ford Idaho's Avatar
Is it the front or back?
If it is then do the whole width, kind of racing stripe style but side to side.
Old 04-15-2016, 06:17 PM   #7
shughey00's Avatar
How big of a section is it. Are you able to use Dicor lap sealant...I say that as I know some TPO bubbles with standard Dicor. That I read off of Dicor..actually they have a flow chart that tells you if you can use standard Dicor on a TPO roof depending on whether the TPO has felt on the backing or not.
Anyway if you can then you could put down the Eternabond then put a layer of Dicor tan roof sealant over that...verses just the white tape. If it is on the flat then self leveling will flatten out nice....if it is on the side then non leveling and use a wet finger or an ice cube will tool it nice and level.
Most videos put out by RV repair show them putting Dicor over at least the edges of the Eternabond to keep water and wind from aging the edge. Granted I can never pull that stuff up but over time I can see it.
Anyway might be a possibility.
This is a link to the Dicor page on TPO...
http://www.dicor.com/ultrasealant/
shughey00 is offline   Reply With Quote
Old 04-15-2016, 06:20 PM   #8
bubbles's Avatar
It is also available in black. May look better.
Old 04-15-2016, 07:25 PM   #9
Again, thanks for the suggestions. for Ford Idaho: It's on the front, on the slope behind the front cap. From Shughey00: If you look at my picture, I think my original patch was 16 X 20. The caulk I used originally, was from the Alpha kit and was said to be self-leveling. I was not impressed as it didn't level and really didn't stick very well though I'd gone to a lot of work to prepare the area. The periphery of the where the patch was, is shown in the residual, Alpha caulk. I may have missed something but I only see the Dicor in white. This TPO is the smooth backed type. In my opinion, the TPO wasn't bonded very well originally. There are areas where there is no bonding and the lose TPO in the area exposed, has no indication of ever being bonded, that is, it's totally smooth on the back side.
Old 04-15-2016, 07:30 PM   #10
heavynlori's Avatar
Eternabond comes in white, black and tan and possibly grey ( i think there were 4 choices when we ordered tan for ours)
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
roo, roof
