Old 12-28-2013, 07:57 AM   #1
AKA: 'tiredTeacher
awellis3's Avatar
Running an aux. power cord
Since I no longer have a mouse hole to run my extension cord for my electric heater, I must find a solution. I could run it under the dinette and out the door of the storage bay, but that would mean leaving the outside door open.
Has anyone run an extension cord past the seals on a slide?
Wright and Penny
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 12-28-2013, 09:23 AM   #2
jtstromsburg's Avatar
I have run one thru the seal in our old tt. Works well. To keep critters from climbing it, I took the male end off, slid a funnel on, then reattached the end. Funnel stays on the cord and mice can't climb past it (I think) worked for me
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 12-28-2013, 03:14 PM   #3
Dave_Monica's Avatar
You can buy an exterior male 110V receptacle to run the extension cord to. I have one mounted and wired to a dedicated plug inside to run an extra heater if needed. You probably can only use the 20A outlet at the site post for extra power if it's 20/30/50A. If it's 20/30A service, the max is most likely limited to 30A as both outlets are usually supplied with the same wire.
