Closed Thread
Old 04-19-2019, 09:35 PM   #1
cmac7203's Avatar
Running TT Marker Lights
Does anyone know how to turn on camper marker lights while NOT hooked up to TV? Iíve seen a thread that mentions a jumper on the 7-pin connector but canít find it.
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
cmac7203 is offline
Old 04-19-2019, 09:48 PM   #2
Jayhawker
Jayhawker's Avatar
Try this.
Jayhawker is offline
Old 04-19-2019, 11:05 PM   #3
bob213's Avatar
For an emergency situation where you might want them to flash a standard auto flasher plugged in the same way will make all of them flash. We've used this to let emergency personnel know where to go.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ė Ayn Rand
bob213 is online now
Old 04-20-2019, 06:53 AM   #4
cmac7203's Avatar
Originally Posted by Jayhawker View Post
Try this.
Great...thanks!
cmac7203 is offline
Old 04-20-2019, 06:53 AM   #5
cmac7203's Avatar
Cool idea!
cmac7203 is offline
Old 04-20-2019, 06:58 AM   #6
SPRING IS COMING!!!
Never thought about using a fuse, I just made up a jumper with 2 crimp on spade connectors. Just be careful not to bend the connector blades inside the ports so that they won't make proper connection when plugged in.
It's the 2 ports below the "notch" on the outside of the connector.
BriaBeck is offline
Old 04-20-2019, 08:16 AM   #7
Grammar Pedant
67L48's Avatar
There's actually a commercial product that will do this for you for $10 called the Nappy Camper. I don't have one and am not endorsing this. Just giving an additional option.
It's a cap and you can see how the jumper is built-in:
RV: 2018 Rockwood Mini Lite 2504S
67L48 is online now
Old 04-20-2019, 08:16 AM   #8
Misfit Adventures
Misfit011's Avatar
Brother in-law uses a wire for his a fuse much safer it's what I have . Always have one laying around lol
Misfit011 is offline
Old 04-20-2019, 08:17 AM   #9
stormer's Avatar
Nice! I saw someoneís TT at a campground that had their running lights on and wondered how they did that! Pretty cool! Thanks for post!
James
James & Aimee
2018 Rockwood 2906WS
2012 Ram 2500HD 6.7L Cummins
Equal-i-zer 4 point hitch
stormer is offline
Old 04-20-2019, 08:20 AM   #10
Just remember...depending how the CG is situated and locations of the pads, someone behind you may not appreciate your running lights shining in their window all night long.
TheWolfPaq82 is offline
Closed Thread
light
