Old 04-25-2016, 02:05 PM   #1
Charles Firth's Avatar
RV parts help.
I discovered 2 weeks ago during a trip, that the Windjammer toilet would not hold water, it leaks out slowly. I think I asked for some ideas on this forum, and was told that the gasket for the slide was probably dry and there is a product that you poor in the toilet, let it sit and it kinda lubricates the gasket. Well, I went to my local RV store today and the salesman said it was a waste of money. It either needs a good cleaning or replacement. Sounds reasonable. I told him the toilet held the rv antifreeze all winter with no problems. He asked why did I put antifreeze in a toilet that did not have water, that was a waste. I thought you put the antifreeze in the toilet to keep the gasket moist..I walked out of the store did not buy anything. I will clean the gasket and lubricate it with some petroleum jelly and see if that works. Kinda felt stupid when I left, I thought I had been doing things right.Any thoughts ???
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 04-25-2016, 02:13 PM   #2
Iggy's Avatar
Charles Firth
Dealer wants to sell you a new toilet.
It is the seal and if you have gloves reach down there and pull it back up in place and see what happens.
You can also buy a new seal and it can be installed from above without removing the toilet. Gloves needed for sure.
Good luck
Old 04-25-2016, 02:25 PM   #3
Flybob's Avatar
Do not use petroleum jelly as the name says it is a petroleum product and can damage the seal. Pick up a small tube of silicon pool lube at any pool store. You only need a very thin film. If that doesn't work, you may need to replace it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-26-2016, 11:00 AM   #4
fil564's Avatar
I leave antifreeze in the toilet all the time in the winter, we store ours in a mine but i still blow out the lines and pour antifreeze in the traps and the toilet so there is no evaporation of water and odor. Use some plumbers silicon which you can pick up at HD or Lowes.
Phil
2012 Ford F-350 Lariat Crew Cab 6.2L FlexFuel
2014 Rockwood Windjammer 3008W
fil564 is offline   Reply With Quote
Old 04-26-2016, 11:02 AM   #5
B and B's Avatar
I have used cooking oil when camping, works.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-26-2016, 05:03 PM   #6
Left Coast
X2
Old 04-26-2016, 06:40 PM   #7
I worked on the toilet today ( sounds like fun ) cleaned it real good and lubricated the seal with some silicone spray. I discovered that the ball was not completely closing after a flush, thus was allowing water to escape slowly out the trap. Don't know for sure but after lubrication and cleaning it was holding water. I will check it in a few days to see if the water is still holding. One thing I discovered, just like someone stated after use you need to release the foot lever and let the value "slam " then it seats correctly and holds water. Thanks for the help, I am sure I will be asking for more later.
Old 04-26-2016, 07:02 PM   #8
Real men don't need gloves! LOL!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 04-27-2016, 08:16 AM   #9
Klbrown53's Avatar
Recently was holding a small tactical flashlight above ours shining the light down through the toilet. (My reason is too long to go into) so, anyone guess what happened? I saved it before it disappeared but it did scare the crap out of me (pun intended). Scrapped the back of my hand getting the light out and was just thankful my hands are not bigger. Kind of like hand in the cookie jar, hand fits fine until you grip something then fit is a bit tighter.
Tired of talking about this crappy subject now.
Klbrown53 is offline   Reply With Quote
Old 04-29-2016, 01:08 PM   #10
Checked the toilet after 3 days still holding water. The silicone and a good cleaning worked. Thanks again for the info.
parts
