10-25-2017, 10:25 PM
RV waste tote transport
Recently picked up a Barker waste tote. DW says no way is it getting transported in the bed of the truck ( and I agree ). Looks like the only place that will work on our TT is the roof access ladder. Pretty sure I can work something out for securing it to the ladder. However, asking to see how others might have done this. Sometimes others have great ideas that would never have occurred to me.
Thanks,
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
10-26-2017, 06:29 AM
Don't look in the bed of my truck...that is where mine goes :-)
Have seen several ways. Use a cargo rack on the rear of the RV and store it there. Attach it to the ladder on the rear of your RV...if you have one. For that, you can use the device used to carry step ladders, chairs etc.
2023 Rockwood Signature 2442BS
2022 Ram 3500 Longhorn Limited
10-26-2017, 07:16 AM
We carry ours in the bed of the truck when going somewhere it's needed.
Curious as to why you wouldn't consider hauling it there?
10-26-2017, 07:33 AM
I have found that if you have NOT "Ripped/Torn/Drug" off your "Step Boxes" you can MFG supports for Under Frame use/storage as long as the Supports don't hang Below the "Step Box"! Youroo!!
What is wrong with carrying it in the bed of the truck?
2009 Silverado 2500HD
2017 Rockwood 2902WS
2016 Sun Tracker 22 XP3
2018 Ram 2500
2014 Spark
10-26-2017, 07:35 AM
Ours travels in the truck bed.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
10-26-2017, 07:39 AM
Mine fits nicely between fiver hitch and tailgate along with the firewood
10-26-2017, 08:20 AM
If I were to guess at the reasoning for not wanting it in bed of the truck. It would be that there are other items in the bed and there is always the possibility of cross contamination.
2013 Rockwood Freedom2381G
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
10-26-2017, 08:34 AM
I have mine on the back of the camper. Made a “cage” that it sits in which I u-bolted to the bumper, next to the spare tire. And I’m in the process for making another “cage” to store the sewer hose connections so they’re not in a storage compartment “inside” the camper.
In a few days when I get to the back of the camper, I’ll post a pic.
2012 Ram 2500 Crew Cab long bed B&W companion hitch
2015 Crusader Lite 30BH
2019 Harley Tri Glide
KB3FPI hammy
10-26-2017, 09:40 AM
Back of the truck.
2011 Traverse LT, 3.6L, FWD
10-26-2017, 09:54 AM
Truck bed, but interested in seeing Dinosaur's photos.
10-26-2017, 11:01 AM
Bingo.
Tuckerdog1
10-26-2017, 11:05 AM
We carry ours in the Truck bed.
We don't worry about cross contamination because we NEVER use it for black water, only for gray water.
Unless you have a small black tank or are dry camping a long time, I just don't see the need for using it for black water.
10-26-2017, 11:13 AM
Thanks,
Tuckerdog1
Tuckerdog,I Read "Real Plain" that your family said NO to bed of Truck! So like I said before here Might be a Idea/Solution! BAL "Hide-A-Spare" Underslung #28216 made for Covered underbelly units! The Original "Barker 30 Gal Tote is 8-3/4 high" close to tire width,so with a Little "Engineering" and not below the "Step Box" you Might please your Family! Youroo!! We both have V-Nose units sitting on Torsion Axles and 15" tires,I mounted My spare tire in the Front under the frame,cable lift like a PU spare,it has NEVER been in "Harms Way"!
10-26-2017, 12:41 PM
Although I have a Class A, which may not apply to your case, I store mine up underneath the camper between the two main frame members. Regardless, do some thinking outside the box and see if there is somewhere underneath your TT that you can lash it to with some ratchet straps. (Make sure you have clearance while driving.)
2018 Berkshire 38A
10-26-2017, 12:43 PM
Some guy in back...
Carrying the waste tank
We tow with a big Ford van, so I just put the tote in a large plastic bag and put it in the back. Before I used it for Black water (once) last summer) I put it in the van directly, no bag needed.
There is no accounting or answer to a squeamish spouse, so you just need to do what makes them happy.
The "hang on the ladder" approach can be the easiest, since ladder mounts for chairs and bicycles are readily available (hose clamping "L" brackets to the ladder can also work). The "under the rig" approach will likely require some some quality time with a band saw and a welder, but could be a clean way to make it happen.
"Store in the bed" seems to be the most popular with the truck crowd, so that is why there are not so many commercial solutions available.
Good luck!
ChateauV10
St. Charles, MO
Ex-SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
10-26-2017, 12:58 PM
Towing the Honey Wagon
Can I ask a somewhat-related question? Last weekend we heard someone's rig leaving the campground. It was making an odd noise. When we looked closer, we saw they were towing their honey wagon to the dump station. It had two pretty small wheels and he had fastened it to his rear bumper with what looked like bungee cords. Needless to say, we didn't want to get that close. He was only going about 15 mph and it would seem that he made it.
Is this common practice?
Mark
Michigan
2014 a122s
2014 Tacoma Double Cab
My YouTube Channel
Days Camped 2016/2017/2018/2019: 98/106/109/73
10-26-2017, 01:02 PM
If cross contamination is such a concern, you need to rethink the reason you are using a portable waste tank. They are designed to allow you to dump your on-board waste tank contents and haul it elsewhere for disposal. The entire process has the possibility of not being totally spic & span or Mr. Clean pearly white.
Are you going to totally disinfect it before you hoist it up by your face to store it on the rear ladder or bear wrestle with it to get it under the steps or on the rear bumper?
Put your hazmat suits on and let the bashing begin!
10-26-2017, 01:15 PM
I had a local welder build a rack out of angle iron which is attached to the back bumper. Thousands of miles traveled with no problems.
Most are designed to be towed...of course not over rough terrain. Mine is labelled with a placard stating "Do not tow over X mph".
2018 Berkshire 38A
