Old 09-09-2014, 02:38 PM   #1
Safety tie for TV
I purchased a new 2014 Rockwood 2904SS this spring. I recall that while we were looking for the new trailer, that some of the ones we looked at had a sort safety strap going around the LCD TV holding it to the wall mounted bracket. I assumed that was a safety feature to prevent it from coming out of place while traveling. In looking over all my materials that came with the trailer, I cannot find any mention of such a strap nor can I find a strap. Does anyone know is an additional security strap is needed?
diesel901 is offline   Reply With Quote
Old 09-09-2014, 02:57 PM   #2
Oaklevel's Avatar
Don't know about your model ours has a safety strap but you can lift the TV off the wall bracket & use it on an outside mount so I assume that ours has one mainly because the swing arm is sitting in a slide off bracket , possibly allowing the whole TV to bounce off going down the road.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 09-09-2014, 02:58 PM   #3
Smile TV Safety Tie
I simply put a couple of books under the bottom of the TV that squeeze in tight. TV doesn't vibrate when bumping and traveling. Simple but it works!
wyoman is offline   Reply With Quote
Old 09-09-2014, 04:59 PM   #4
I think I had better get some sort of strap or support the tv from the bottom as Wyoman suggests. Sure don't want that thing bouncing off while traveling. I may try a pillow under it. If anyone with a Rockwood 2904SS had a strap as standard equipment I would like to hear from you. Thanks to all.
Old 09-09-2014, 05:31 PM   #5
Fivealive's Avatar
I made up a strap using 1" webbing and fastek buckles. I secured the webbing by using a small metal plates pop riveted to the wall. I put bubble wrap under the strap to prevent chaffing. 2 years and the strap still holds securely.
Fivealive is offline   Reply With Quote
Old 09-09-2014, 05:37 PM   #6
Taranwanderer's Avatar
We use these, not just for the TV but for anything else that needs to be secured while in motion:
TV Hold Down Systems on Sale - PPL Motor Homes
They work well, we keep finding more uses for them.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
safety
