Old 02-24-2016, 05:09 PM   #11
Utah Traveler's Avatar
You're goiong to love it!
Took delivery of my 2016 Rockwood 2109S in late November.
Wife & I love it. Perfect size for the two of us and our dog.
Heat is more than adequate, even on coldest nights. Vents located fore and aft of range and sink,near floor.
Hope you love yours as much as we do. Spring is almost here!
Utah Traveler is offline   Reply With Quote
Old 03-30-2016, 11:22 PM   #12
We have a 2013 2109s. We have camped several nights below freezing; in fact, I had to put an electric heater under the trailer to keep the water line from freezing. The trailer heater inside worked great with just two ducts. Just leave the bathroom door ajar when not in use.
2109s - '14 Jeep Grand Cherokee diesel
EmersonTT is offline   Reply With Quote
Old 04-04-2016, 03:20 PM   #13
How cold did it get? Did the water lines underneath actually freeze or were you just being cautious?
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is online now   Reply With Quote
Old 04-04-2016, 03:33 PM   #14
We're getting so anxious! This Friday will be 6 weeks since the order went in. RVW gave a 7 week estimate and when I called the factory direct at the time, they said 6-10 weeks. Though they also said they were running closer to 6 weeks on them.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
RandK-M is online now   Reply With Quote
Old 04-22-2016, 10:31 AM   #15
GFI reset.
I bought a short 30A male to 15A female pigtail along with a 3-light circuit analyzer for use in checking polarity etc. before connecting to a campground's power. Just to see how it worked I plugged it in to the outside power tap on the RV. The lights lit properly. Well, they did for a short time. When pulling it from the socket I managed to depress the small button on the analyzer that tests for ground faults. It works. Then I had to hunt for the reset button to get things up and running again. It's on the bathroom vanity cabinet. Hopefully, that bit of information will save someone else from spending several minutes searching on their 2109-S
joec is offline   Reply With Quote
Old 04-22-2016, 12:09 PM   #16
Good to know. Thanks Happy camping
2016 Rockwood 2109S
2002 Silverado 1500 5.3 V8
Old 04-22-2016, 04:09 PM   #17
The "trunk line" in the ceiling runs clear to the vent over the toilet. Remove the vent just before the bathroom door and look rearward, you will see some foam in there. Remove and use a wire hanger to verify how far it goes. Then cut in a new one inside bathroom and re-foam the trunk between there and the vent.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 05-12-2016, 01:10 PM   #18
Traveling_Boilers's Avatar
Vents in the ceiling for air conditioning, but not in the bath. The ceiling fan in there works, but only when the bath light is on. Furnace vents are floor level on both sides of the kitchen cabinets.
Traveling_Boilers is offline   Reply With Quote
Old 06-28-2016, 08:57 AM   #19
This forum is really great and I have learned much so far!
We picked up our 2017 2109s on June 1st at RV One in Albany. Did a few days of camping with full utilities to shake it down a bit at Lake George NY and then headed back to Maine. I have the 1000/10,000 Equalizer hitch and it pulled like a dream behind my V8 4Runner except the gas mileage was really horrible....
The only problem so far is that the TV antenna was "caulked" to the roof and wouldn't turn. It took a bit of undoing to get that squared away and then I realized that the plastic nut that holds it to the roof wasn't connected. A 2" 15/16th socket fixed that and it is working fine now.
Got home and started into some mods that I had planned.
The big one was a solar project as we mostly camp at State, National and Provincial parks with few or no hook-ups. I have a portable 100 W panel and I bought two Trojan 6Volt T105's and mounted them on the tongue in plastic cases which I had to modify (cut the handles off and the tabs on the cover where they meet-which I read about in this forum!). I was bummed that the Torklift box I bought from eTrailer didn't fit (https://www.etrailer.com/Accessories.../TLA7712R.html) but they were great about taking the return.
In terms of the solar hookup, I cut the wires between the Zamp plug and the leads going to the battery and made a harness to my solar controller (Renogy Adventurer) which I mounted by the door just below the FR monitoring panel. It took a bit of doing to run the wires and I had to drill a hole in the floor from the shallow pantry below the radio into an existing raceway and then snake my wires through the hollow cabinet floors to where I mounted things. That meant taking the IRV34 out, the hood down and the microwave out but it is finished and working well. (While the microwave is out, it is a simple install for a paper towel rack as you can add a 1/4" piece of playwood and through bolt it above the sink).
I am hoping to run the reefer and some lights and a fan (and maybe the TV for the news) and with the solar panel try to go 10 days. I fired up the refrigerator on propane to see how things will recharge yesterday and it is cloudy here today so this will be a good test.
I also connected a second light to the interior light switch so that when you come in when it is dark, it lights up a bit better than with just the one light over the sink. I also bought a GE LED wireless switch/2 fixture set up (GE Under Cabinet Light Fixture, 12" - Walmart.com) which I will use to try to save the batteries. I disassembed the switch and sprayed it brown to match the outlet in the cabinet by the door and mounted one light bar over the sofa in the slide out and the other under the cabinet to the left of the hood.
Today I am installing two LED reading lights in the cabinets on either side of the bed as the overhead light is terrible and impossible to read by. I also want to swap out the 24" TV with a 19" Insignia that I have that will run on 12V. (I bought the adapter on Amazon). I'll report out on both when I have them completed if I have time as we are leaving in a few days......
I'll try to post some pics of the solar set up later.
Campah
2017 Rockwood 2109s Mini Lite
Campah is offline   Reply With Quote
Old 07-08-2016, 09:29 PM   #20
Saying Hello and questions for 2109S owners
We ordered a 2017 2109s 4 weeks ago and the wait is driving me crazy.
The UPS guy must be going crazy also. with all the Amazon deliveries for trailer stuff. Lol
I'm still on the fence on going with Zamp 200W solar or Yamaha generators. I want to dry camp more than hook up.
2017 Rockwood Minilite 2109S
2017 GMC 2500HD gasser
Markval is offline   Reply With Quote
210, 2109s
