This forum is really great and I have learned much so far!
We picked up our 2017 2109s on June 1st at RV One in Albany. Did a few days of camping with full utilities to shake it down a bit at Lake George NY and then headed back to Maine. I have the 1000/10,000 Equalizer hitch and it pulled like a dream behind my V8 4Runner except the gas mileage was really horrible....
The only problem so far is that the TV antenna was "caulked" to the roof and wouldn't turn. It took a bit of undoing to get that squared away and then I realized that the plastic nut that holds it to the roof wasn't connected. A 2" 15/16th socket fixed that and it is working fine now.
Got home and started into some mods that I had planned.
The big one was a solar project as we mostly camp at State, National and Provincial parks with few or no hook-ups. I have a portable 100 W panel and I bought two Trojan 6Volt T105's and mounted them on the tongue in plastic cases which I had to modify (cut the handles off and the tabs on the cover where they meet-which I read about in this forum!). I was bummed that the Torklift box I bought from eTrailer didn't fit (
https://www.etrailer.com/Accessories.../TLA7712R.html) but they were great about taking the return.
In terms of the solar hookup, I cut the wires between the Zamp plug and the leads going to the battery and made a harness to my solar controller (Renogy Adventurer) which I mounted by the door just below the FR monitoring panel. It took a bit of doing to run the wires and I had to drill a hole in the floor from the shallow pantry below the radio into an existing raceway and then snake my wires through the hollow cabinet floors to where I mounted things. That meant taking the IRV34 out, the hood down and the microwave out but it is finished and working well. (While the microwave is out, it is a simple install for a paper towel rack as you can add a 1/4" piece of playwood and through bolt it above the sink).
I am hoping to run the reefer and some lights and a fan (and maybe the TV for the news) and with the solar panel try to go 10 days. I fired up the refrigerator on propane to see how things will recharge yesterday and it is cloudy here today so this will be a good test.
I also connected a second light to the interior light switch so that when you come in when it is dark, it lights up a bit better than with just the one light over the sink. I also bought a GE LED wireless switch/2 fixture set up (
GE Under Cabinet Light Fixture, 12" - Walmart.com) which I will use to try to save the batteries. I disassembed the switch and sprayed it brown to match the outlet in the cabinet by the door and mounted one light bar over the sofa in the slide out and the other under the cabinet to the left of the hood.
Today I am installing two LED reading lights in the cabinets on either side of the bed as the overhead light is terrible and impossible to read by. I also want to swap out the 24" TV with a 19" Insignia that I have that will run on 12V. (I bought the adapter on Amazon). I'll report out on both when I have them completed if I have time as we are leaving in a few days......
I'll try to post some pics of the solar set up later.
