Old 05-16-2019, 09:15 PM   #1
JerryE's Avatar
Schwintek Slide 2018 Rockwood 2650ws
Hello ,
I have a 2018 Rockwood 2650WS with the Schwintek wardrobe slide , and for the life of me I can not find the control box for it , anyone know where it is mounted ?
JerryE is offline   Reply With Quote
Old 05-17-2019, 08:17 AM   #2
Commercial Member
ES_FR's Avatar
JerryE,
We would be happy to assist you with your wardrobe slide. Please contact Rayna Dimitroff in our Customer service department through the following personalized and direct link: Forest River RV Direct Service Contact - Forest River, Inc..
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 05-17-2019, 09:16 AM   #3
They are often put behind panels that are not easily opened. Usually screwed shut somehow. Mine is behind this panel that has 2 hinges on one side and one hinge on the other. You have to unscrew the single hinge to swing the panel open.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 05-18-2019, 12:18 AM   #4
That's pretty interesting.
We have a 2018 2608SB and I had your exact dilemma ..... where the heck is the control panel for the wardrobe side.
I went back to the dealer. Thankfully in our SB model with the extensive pass-through storage area under the bed ... and the edge of the wardrobe side .... the control panel was easily found. I was embarrassed. It is right there ... hiding in plain view .... just stuck my head in a little and the panel is mounted to the left. FR did this one right!!!
Hope you have as much luck.
Cheers,
John
2012 Dodge Ram 1500
2018 Rockwood Ultra Light 2608SB
john a v is offline   Reply With Quote
Old 05-19-2019, 06:54 AM   #5
tootall1
Control box
Excellent response ES-FR. The members should be happy Forrest River
responded on this.
Maybe they are monitoring messages to see if they can help. This great for
us and very good for them. Itís called great customer service!
tootall1
tootall1 is online now   Reply With Quote
Old 05-19-2019, 08:28 AM   #6
tcp
Jerry -
We have a 2017 Rockwood 2650 WS. Our controller is mounted opposite of the slide in the pass thru storage.
tcp is offline   Reply With Quote
Old 05-19-2019, 02:08 PM   #7
OldGuysRule
Renegade837's Avatar
Mine was under the floor in the end closet, between the water bunker and the end of the nose storage. It was mounted to the floor under the water lines. If that's where you find yours, do yourself a huge favor, and either relocate it to an adjacent area, or get a waterproof box to mount it in. Mine got wet, and burned out the motors in the process. The control panel alone is 600 and the motors are 250 a piece. Big fat thank you to Forest River.
Renegade837 is offline   Reply With Quote
Old 06-02-2019, 11:15 AM   #8
JerryE's Avatar
John ,
Would it be possible to post a picture of where you found yours I am still looking blind I still can not find it , thanks
Old 06-03-2019, 07:56 AM   #9
OldGuysRule
This isn't the best pic, I'll try to get more this weekend. As you are facing the camper's nose, to the right side near the front is a small bunker where I attach the water hose and the cable tv. This photo is the back side of that bunker. I got to it by going into the closet in the bedroom (which was right above this) and removing a screw in floor panel. Good luck!
rockwood, slide
