Old 04-01-2014, 05:50 PM   #1
screws on hydraulic door closer
There are 3 screws on the door closer bracket that is mounted to the door. Two of those screws appear to be in sheet metal only while the middle one is in the heavier door frame metal. As would be expected, the two in the sheet metal have stripped out.
Does anyone know of an easy repair to keep the sheet metal screw tight without having to relocate the bracket? Does anyone think J-B Weld or Gorilla Glue might do the trick? Thanks in advance.
2014 Ford F250 Lariat
2014 Rockwood Signature Ultra Lite 8280 WS
Louisiana before, fulltiming since April 11, 2014
blog--- www.gozatravels.blogspot.com
Darrell is offline   Reply With Quote
Old 04-01-2014, 05:53 PM   #2
Ford Idaho's Avatar
How about a couple of Nutserts?
https://www.google.com/#q=nutserts
Old 04-01-2014, 05:58 PM   #3
Removed the 3 screws and used 3/16" pop rivets on mine 2 yrs ago and no problems since and they are still tight.
Name:	Both anchors relocated.jpg
ID:	48953   Click image for larger version
Name:	Close up door anchor relocated.jpg
ID:	48954   Click image for larger version
Name:	Close up relocated anchor on trailer.jpg
ID:	48955   Click image for larger version
Name:	Door anchor relocated.jpg
ID:	48956   Click image for larger version
Name:	Relocated anchor on trailer.jpg
Old 04-01-2014, 06:20 PM   #4
B47
We called them "RivNuts" - same thing.
Old 04-01-2014, 06:37 PM   #5
Ford Idaho's Avatar
I used four of the larger sized ones to bolt a crossover tool chest to a pickup bed.
Never moved in five years, they be strong stuff .
Old 04-01-2014, 06:40 PM   #6
B47
We used them in some secondary structure applications - cargo bin floors,etc.
Old 04-01-2014, 06:42 PM   #7
Not much thickness for them.
Old 04-01-2014, 06:45 PM   #8
B47
If appearance isn't a concern, could a couple of fender washers be used as doublers?
Old 04-01-2014, 06:50 PM   #9
Ford Idaho's Avatar
It would be hard to get them behind the skin of the door.
The skin needs to be between the lip of the sert and the washer.
Old 04-01-2014, 06:54 PM   #10
Just use pop rivets and the job is done is 5 minutes or less.
door, hydraulic
