Old 04-07-2014, 01:47 PM   #1
Charles Firth's Avatar
sewer hose storage
Currently I have my sewer hose stored in a plastic container with a lid. The hose is new and has not been used yet. The box takes up considerable room in my windjammer and I could use the room for other things. Also after the hose is used and washed I think I would feel better if it were not stored under the dinette. I like the PVC fence pole covering that people are using for the hose storage. My TT under carriage is closed off, so it will have to be mounted on the rear bumper, will those heavy duty plastic ties hold so it won't be lost on the road ? There have been several posts covering this topic I have seen them mounted under the TT, but can't quite make out how they are attached to the rear bumper. Thanks in advance Chuck in Va
Charles Firth is offline   Reply With Quote
Old 04-07-2014, 02:20 PM   #2
fonzie's Avatar
Possibly large cable ties would be OK but I would go with square U bolts instead available at hardware stores.
Fonzie
Old 04-07-2014, 02:26 PM   #3
Store 2 in the round tubes by the dump and 2 under the back bumper. Tubes are strapped and bolted to the frame and the 2 under the back bumper are on a 1/2" threaded rod with a cross bar under them.
Name:	Sewer Hose Storage.jpg
ID:	49306   Click image for larger version
Name:	Sewer hose, connections & Driver side Sun Shades.jpg
Old 04-07-2014, 02:29 PM   #4
Webfoot
I just completed adding a 5" PVC fence post with a gutter inside for our sewer hose. I ended up mounting just in front of my front scissor jacks with 7" worm-drive pipe clamps. I was able to find two pieces of metal that were connected to the frame that I was able to strap on to.
I wasn't able to fit the post on top of the bumper because it would have gotten in the way of access to the water heater, and putting below I was afraid of bottoming out with it. The trailer is at storage this week, but will get pictures this weekend.
2012 Chevy Suburban 1500
2012 Surveyor SP-260
quackor is offline   Reply With Quote
Old 04-08-2014, 10:27 AM   #5
Helmsey's Avatar
At one point on my last 5er I had the fence post attached to the rear bumper with several zip ties and had no problems on a 600 mile trip.
After I got back from that trip I ended up using something like what Fonzie posted to hold it in place.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 04-08-2014, 10:40 AM   #6
thegreatoutdoors's Avatar
I just pulled of the plastic end caps on my rear bumper and store it in there. Out of the way, and not to difficult to retrieve.
2014 Salem 26TBUD
2014 Ford F-250 SuperCrew 4x4
2001 F150 SuperCrew(Retired from service)
thegreatoutdoors is offline   Reply With Quote
Old 04-08-2014, 10:54 AM   #7
Camper Less Camping
Cajun Po-Boy's Avatar
I use the bumper space for the rear laundry hanger assembly...so the 5"PVC works out great for both sewer hose and portable grey tank hoses and fittings ,)
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-08-2014, 11:08 AM   #8
Thats cool. got any pics?
2014 Salem 26TBUD
Old 04-08-2014, 11:10 AM   #9
BigTJohn's Avatar
Trouble with using the bumper to store the hose is that it will rust, it will rust if you don't store the hose there. Need to "swab" it out with a giant cleaning rod/wire. A rag sprayed with some water proof lube (Boeshield T9) will do wonders. Storing the plastic hose in a plastic pipe makes all kinds of sense. Metal tube will grind away at the hose causing leaks. IMO.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 04-08-2014, 01:59 PM   #10
Thanks for the reply's, I believe the fence post cover will suit my needs. The fence post pvc cover at Lowes about $20.00. Still looking for the long u bolts to bolt it to the rear bumper, lowes didn't have anything that large. I will check some local hardware stores. Thanks again for the responses.
Old 04-08-2014, 02:05 PM   #11
Might use some angle iron and threaded rod instead of U bolts or what they call holey iron (straps with holes in it) and just plain bolts.
Old 04-08-2014, 02:36 PM   #12
jtstromsburg's Avatar
Mine are bolted with little ss #12 machine screws with locks and flats, from inside the post thru a couple "L" angle brackets. The brackets were fastened up to the frame first. I like it because you can't see any fastening system. It's held one full season and I'm hoping I don't find the whole setup dragging someday.
Sent by me
ID:	49406   Click image for larger version
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-08-2014, 02:52 PM   #13
PhoneDude 8289's Avatar
Mine are held up by 5/16 rod thru 1" aluminum angle behind the rear axel.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-08-2014, 02:53 PM   #14
BamaBob's Avatar
Another thing...
If you use a Rhinoflex sewer system (you DO, don't you?!) The attachments on the end of the sewer pipe are too big for a bumper.
Sure you can "unscrew" them but then you are storing the sewer stuff *somewhere*
X2 for the PVC mods!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-08-2014, 03:28 PM   #15
Owner/Operator
RodeoGeorge's Avatar
AN alternative to U-Bolts is to drill a 1" hole in the bottom of the fence post at the location where you want to mount the post, and a proper size hole (based on the bolt to be used) on the top of the fence post opposite the large hole.
I then use an extension to access the mounting bolt through the bottom of the post. I use a large (1/4 X 1-1/2") washer under the head of the bolt to distribute the mounting force.
I tried reaching into the post to turn the mounting bolt, but found that to be awkward.
The hole in the bottom also provides a place for water to drain out of the post.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 04-08-2014, 05:06 PM   #16
Steeljag's Avatar
I've used my bumper storage for three years without issue! It is a Rhino, and the ends do fit (on mine).
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 04-08-2014, 05:13 PM   #17
Ford Idaho's Avatar
You mean something like this?
Clopay Garage Door Rear Track Hanger Kit-4125478 at The Home Depot
Old 04-08-2014, 05:15 PM   #18
Originally Posted by Ford Idaho View Post
No, just the holey strap.
Old 04-08-2014, 06:40 PM   #19
Oklahoma Proud
MillerTime's Avatar
I love the post covers too.
I made my own brackets, and had to space the post cover down because of propane line on the frame.
Now I need to make a new one to hold 3 or 4 for our new 5er.
MillerTime- Future Sabre Handler!!
ID:	49418   Click image for larger version
ID:	49419   Click image for larger version
Old 04-11-2014, 09:16 AM   #20
Originally Posted by HSVBamaBob View Post
Another thing...
I store my Rhinoflex in the bumper. I have to rotate it a bit on one of the ends after I slide it in, but it fits with the caps on.
IndyCamp is offline   Reply With Quote
storage
