Old 06-05-2016, 07:16 AM   #21
B and B's Avatar
I replaced my valve in the loo. The one in the galley seems to be OK so far.
B and B
2017 Heartland Bighorn 3575 Elite
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 06-05-2016, 01:32 PM   #22
Keep both grey and black tank valves closed until you are ready to dump. Always best to dump full tanks
Rockwood signature series 8329SS Diamond package. Permanent campsite.
rockjohn is offline   Reply With Quote
Old 06-05-2016, 05:09 PM   #23
Croaker's Avatar
Regardless of how everyone uses their valves...
The sewer gas should not be sucked into the living space by negative pressure created by the Maxair fan.
Either the Air admittance valve is bad (or not designed to handle negative pressure)....or there is a leak somewhere.
Croaker is offline   Reply With Quote
Old 06-05-2016, 05:46 PM   #24
Could very well be the black tank valve under the bathroom lavatory that is defective. I removed mine completely along with all the hose.
Old 06-05-2016, 05:53 PM   #25
Isn't this valve on the sink drain which empties into the grey water tank, not black? What am I missing here?
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 06-05-2016, 05:58 PM   #26
The valve is piped directly to the black tank flusher.
Old 06-05-2016, 06:40 PM   #27
B and B's Avatar
So where is your a vacuum break now?
B and B
Old 06-05-2016, 06:44 PM   #28
Was deposited in the garbage can. Don't need a vacuum break on a pressure water line and the tank is vented anyway. Works just fine if not better due to getting rid of the 90d elbow.
Old 06-05-2016, 06:48 PM   #29
nomad297's Avatar
You obviously don't know much about the consequences of a cross connection.
Bruce
Old 06-05-2016, 06:51 PM   #30
Bruce
Nothing to cross connection or contamination. The inlet hose still goes into the tank flush as it did before, just eliminated a useless valve restriction and about 7' of hose.
Name:	Black tank back flow valve 1.JPG
ID:	110234   Click image for larger version
Name:	Black tank back flow valve close up.JPG
roo
