Old 05-31-2015, 01:11 PM   #1
redcloud1's Avatar
Shake rattle and roll
We have a Rockwood 3008 with the Electric stabilizer jacks. when set up with the jacks extended we are getting a lot of bounce in the trailer when walking around. is there any way to stabilize the trailer because the electric stabilizer jacks don't really do that good of a job.
redcloud1 is offline   Reply With Quote
Old 05-31-2015, 01:42 PM   #2
bikendan's Avatar
Are you using tandem wheel chocks?
If not, that's the first place to start.
Equalizer WDH
Old 05-31-2015, 02:02 PM   #3
Scubanut's Avatar
Try using the xchocks, you will truly be amazed at how well they work.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 05-31-2015, 02:05 PM   #4
Scubanut's Avatar
Name:	ImageUploadedByForest River Forums1433099159.448766.jpg
Old 05-31-2015, 02:45 PM   #5
redcloud1's Avatar
Ok I'm using one but I suppose I need to have one on each set of wheels
Old 05-31-2015, 02:48 PM   #6
bikendan's Avatar
Yep!
Equalizer WDH
Old 05-31-2015, 03:10 PM   #7
Scubanut's Avatar
X2
Old 05-31-2015, 03:22 PM   #8
Additional help is either JT Strongarms or a homemade version of them and jacks in front of the front axle to the suspension 2 x 4 framework.
Old 05-31-2015, 07:30 PM   #9
We use X-chocks as well. We had a little tire problem and changed out all the load range C tires for load range E Maaxis. We aired them up to sidewall pressure and found out the bounce was gone. This was a real side benefit as the trailer would bounce when I turned over in the front bedroom and my wife was watching tv in the back of the trailer. I do not recommend going out and buying a set of tires hoping this will take care of the problem, but when it is time to get new tires it may be worth the extra expense. I just wanted peace of mind with better tires.
Durell
Durell is offline   Reply With Quote
Old 05-31-2015, 07:35 PM   #10
markb5900's Avatar
If you still aren't happy after x chocks (what I use), then go to the auto parts store and buy 4 screw type jack stands and put them mid trailer in the front and back, it will be ROCK solid then.
Pain to put down and take out.
I was in a trailer at a campground awhile back and asked how it was so SOLID, he took me out and showed me the jack stands. That trailer was as solid as any house.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
