06-26-2016, 11:14 AM
Sharp bed frame Corners
The corners of the end of the bed frame are metal reinforced corners and are very sharp. If the mattress, which is very light, moves over by accident, it is easy to scrape my leg against it. I temporarily taped pipe foam insulation on it and it isn't staying on every well. I am looking for a more permanent solution. Any ideas?
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
06-26-2016, 11:43 AM
Can you post a picture of the bed corner?
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
06-26-2016, 04:17 PM
I found the answer! Sorry, I can't post a picture because I just took the trailer back to storage. I did a search for "corner guards" and found some foam corner guards at Home Depot. They come with a light self adhesive that doesn't stick very well so I screwed them onto the plywood. Problem solved!
06-26-2016, 07:14 PM
Had a similar issue with wood corners ripping into mattress back when lifting up storage. Bought child safety bumpers for corners and that fixed that. Might work for your problem.
06-26-2016, 09:43 PM
Good to know, I may need to do the same. Thanks
Al
06-26-2016, 11:39 PM
Blam, I didn't think of the sharp corner tearing the mattress when
lifting the bed up so I'm glad that you brought it up. If my corner guards don't work, I will use your solution. Thanks!
06-27-2016, 09:07 AM
Here is a picture of the corner guards that I used.
06-27-2016, 05:44 PM
bed corner
Okay, call me cheap! I cut the bottom corners off of a square plastic ice cream bucket and tacked them onto the sharp corners of the plywood deck under the mattress. Works fine and I got to eat the ice cream.
06-27-2016, 07:38 PM
Why not sand off the corner a bit to make it round? Even cheaper.
2011 Traverse LT, 3.6L, FWD
06-28-2016, 08:39 AM
I like the ice cream bucket solution! Unfortunately, my model has aluminum frame around the wood so it couldn't be sanded.
06-28-2016, 08:48 AM
Okay, filed then!
I like the ice cream bucket idea too.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
