Old 06-26-2016, 11:14 AM   #1
Sharp bed frame Corners
The corners of the end of the bed frame are metal reinforced corners and are very sharp. If the mattress, which is very light, moves over by accident, it is easy to scrape my leg against it. I temporarily taped pipe foam insulation on it and it isn't staying on every well. I am looking for a more permanent solution. Any ideas?
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
lakejumper is offline   Reply With Quote
Old 06-26-2016, 11:43 AM   #2
SailorSam20500's Avatar
Can you post a picture of the bed corner?
Al
Save the Earth. Its the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 06-26-2016, 04:17 PM   #3
I found the answer! Sorry, I can't post a picture because I just took the trailer back to storage. I did a search for "corner guards" and found some foam corner guards at Home Depot. They come with a light self adhesive that doesn't stick very well so I screwed them onto the plywood. Problem solved!
Old 06-26-2016, 07:14 PM   #4
Had a similar issue with wood corners ripping into mattress back when lifting up storage. Bought child safety bumpers for corners and that fixed that. Might work for your problem.Click image for larger version
Name:	ImageUploadedByForest River Forums1466986456.753757.jpg
Blam is offline   Reply With Quote
Old 06-26-2016, 09:43 PM   #5
Good to know, I may need to do the same. Thanks
Al
S.E. Mich.
Old 06-26-2016, 11:39 PM   #6
Blam, I didn't think of the sharp corner tearing the mattress when
lifting the bed up so I'm glad that you brought it up. If my corner guards don't work, I will use your solution. Thanks!
Old 06-27-2016, 09:07 AM   #7
Here is a picture of the corner guards that I used.
Old 06-27-2016, 05:44 PM   #8
frozen's Avatar
bed corner
Okay, call me cheap! I cut the bottom corners off of a square plastic ice cream bucket and tacked them onto the sharp corners of the plywood deck under the mattress. Works fine and I got to eat the ice cream.
frozen is offline   Reply With Quote
Old 06-27-2016, 07:38 PM   #9
Why not sand off the corner a bit to make it round? Even cheaper.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-28-2016, 08:39 AM   #10
I like the ice cream bucket solution! Unfortunately, my model has aluminum frame around the wood so it couldn't be sanded.
bed, frame
