Old 12-24-2013, 12:07 AM   #11
Originally Posted by Dwilki View Post
JD.....is your shower wall smooth or rough finish? If the interl
ocking caddy stays on a rough finish.....I will order after the holidays since I can't locate one in the BBnB stores. Thx
The walls of our shower are totally smooth. Even though it locks down, it might not work on "pebbled" walls. What's nice about smooth walls, I took a locking hand hold (from Camping World), turned it sideways and mounted up from the floor so that I had a place to balance a leg when washing a foor (or leg shaving). Works great.
JD
Lawrence, JD and JJ
2017 Champagne 38EL
Our Rolling Earthquake
Freebirds is offline   Reply With Quote
Old 12-24-2013, 06:21 AM   #12
VikingsFan's Avatar
In our shower we install a trio soap dispenser like the Better Living AVIVA Trio Dispenser found on Amazon. I was looking for something that could be put in the corner and not use any more room than it had to in the tight quarters of the shower. We used the two way tape and silicone to install it in the corner. So far it have worked wonderfully!
Amazon.com - Better Living AVIVA TRIO Dispenser, White - Shower Dispensers
2013 Shamrock 25RS
2001 Chevrolet Silverado
VikingsFan is offline   Reply With Quote
Old 12-24-2013, 06:55 AM   #13
lswartz's Avatar
We bought a shower basket from Walmart with what looks like adhesive backing. I hope it will stay on that rough surface of the shower wall. Still haven't picked the spot to put, DW will do that . We have been putting everything on the sink counter & dropping them into the sink when finished. Only a few water drop to clean up this way.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 12-24-2013, 08:10 AM   #14
mjones12's Avatar
JD
That foot rest is a great idea.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 12-26-2013, 07:01 AM   #15
we also bought a shower curtain with pockets in it. we bought a towel holder from the container store that fits on the top and bottom of the door made from bungee cord.
http://www.containerstore.com/shop/b...uctId=10015551
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 12-29-2013, 05:33 PM   #16
Originally Posted by Sargent's Fox Hole View Post
I just set them on the bathroom sink, close to the shower curtain, and just reach out and get the one that I need to use.
Not a perfect solution, but it works for me.
That is what we do also, it works out good. We do military type showers so the water is off when we're reaching for the items on the sink. 30 gallons of gray water fills up quickly so rationing water is a good thing for a longer stay with no sewer hookups.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 12-29-2013, 08:18 PM   #17
We also turn the water off between wet & rinse time. However, I would not want to open the door for each item - brrr - it gets cold. I even dry while still in the shower..lol.
After I am clothed, then I use shower spray on the walls every single time. Our previous Cedarcreek shower still looked new when we traded it in.
JD
Lawrence, JD and JJ
2017 Champagne 38EL
Old 12-30-2013, 03:40 PM   #18
Hawksclaw553
shower rack
I just took a vinyl coated shower rack that I bought at Home Depot and bent the top that normally hangs from the shower head in a U shape and hung it on the inside of the shower. Works great.
Hawksclaw is offline   Reply With Quote
Old 12-30-2013, 08:55 PM   #19
Can you post a picture of that?
Randy & Liz
Edmond, OK
2014 Rockwood 2109s
2008 Dodge Ram 1500, Crewcab, 4.7Ltr, 2WD
2014 Camping Nights = 0
Randy-OK is offline   Reply With Quote
Old 01-01-2014, 12:28 PM   #20
Shower caddy dilemma solved
I was in the attic yesterday and found this mesh shower caddy from a past application that I had forgotten about. We added a middle grommet and plan to hang it from the shower rings on the inside of the shower. We also plan to add more clips from the shower ring track to the ceiling for more hanging strength.
I'm new to the forum and hope this .jpg pic attaches.............Thanks to all that shared their shower caddy ideas.
Dwilki is offline   Reply With Quote
210, 2109s, show, shower
