07-01-2018, 11:23 PM
Sig ultra lite 8329ss bed slide
Hello all. I have a question about the bed slide in my 8329ss. It moves by a single gear rail. When it slides in or out, it does not move square. As it moves, it shifts from side to side not straight out. Need help identifying the issue. Thanks for any help you all can provide
Rich
Rich
2018 Rockwood Sig 8329
2017 F-150
07-02-2018, 06:18 AM
If it goes in and out without binding and seals at the end of the travel is the back and forth motion really an issue.
Retired Navy
2016 Flagstaff 26 FKWS
07-02-2018, 06:27 AM
Ours does too although not a lot and it never binds. The motor never seems to work harder.
Sent from my SM-G960U using Forest River Forums mobile app
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
07-02-2018, 08:47 AM
Rich
Ours does the same thing. I was wondering if there was something wrong also, but it hasn't been a problem.
07-02-2018, 01:12 PM
"Don't Tread on Me"
My does this as well. Never been a problem. Agree that having it on 2 would have been a better idea.
Steve J.
Retired VA Law Enforcement , Good Sams Life Member
Rockwood Roo 235S
2002 F-250 7.3 Diesel Powerstroke Powerhouse
Chipped, Bank's Exhaust - "Bad to the Bone"
07-02-2018, 04:41 PM
code.org
Bedroom slide in my 8329ss does the same. I watch it carefully each time but it always seems to end correctly lined up. Pretty crazy watching it weave back and forth.
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights '21-42 Nights '22-86 Nights '23-65 Nights
07-03-2018, 12:07 AM
Not really an issue, just don’t want it to turn into an issue down the line.
Rich
2017 F-150
07-03-2018, 04:59 AM
Have you used any of the slide lube on it? The one on our V-Lite seems to move pretty evenly. I used the dry lube several times a year.
07-06-2018, 03:57 PM
I actually used lube right before the start of our trip. I can keep it straight if I have someone push the button. I am going to investigate more when I am on a cement pad large enough for me to lay to take a look
Rich
2017 F-150
07-14-2018, 06:09 AM
I have the same issue with our bed slide. I think the slide mechanism is a LCI Lo Profile slide system. At the end of travel, the bed shifts side to side but it always seals correctly. I do have som metal filings under the bed so I'm gonna check it out in more detail today. Can't find any into on the LCI website except how to adjust the in and out stops.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
07-14-2018, 08:54 AM
I believe any slide with a single mechanism is going to wobble a bit; it's the nature of the beast.
2011 Traverse LT, 3.6L, FWD
08-22-2018, 10:56 AM
Broken Toe
Had a tech look at mine at Goshen. He explained that in certain configurations, they cannot put the actuator in the center of the slide. When that happens, due to 'slop' (my term) in the rack and pinion setup that keeps it square, you get a bit of 'wander' as it opens and closed. Its really pronounced in a bed slide because the movement is amplified due to the length of the bed. What might be half and inch at the headboard becomes 3-4 inches at the other end due to the lever-arm action of the bed.
I had the tech (and another one outside) watch the action thru 3 close-open cycles and they said that while disconcerting, its normal for this type of setups and nothing to worry about.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
08-23-2018, 09:03 AM
Bed slide
We have an 8332BC and the bed slide does the same thing. Must be norm. Glad someone posted on this issue.
