Old 01-29-2012, 08:57 PM   #11
Originally Posted by Steve Lange View Post
We purchased ours at the Louisville Ky. RV Show two years ago. Picked it up first week of Feb. and proceeded to tow it 2200 miles on a trip to Florida. Had a screw back out on the slide and a leek in the city water inlet last year. Both are repaired and ready to roll. Does the 2012 model have the sliding bedroom door? I changed ours to a slider the first few months we owned it.
Hi Steve,
Yes, the 2012 does have the sliding bedroom door.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 04-17-2012, 09:50 PM   #12
Television Problems
Has anyone had a problem with the mount for their Television? Screws keep coming loose, worried that TV will fall off one of these times we're traveling.
Joepellegrino is offline   Reply With Quote
Old 04-21-2012, 12:08 PM   #13
Steve Lange's Avatar
We have not had any trouble with our TV. I do not even know how to take it out. I agree with your concern, with all the movment going down the road it would be likly to fall. You may want to check and make sure it was mounted into studs not just the paneling. Good Luck !!!!
Steve and Jeannie Lange
Erlanger, Kentucky ( Northern Ky )
2010 Rockwood 8314BSS
2007 F250 4x4 Crew Cab 5.4
2010-8 trips/27 nights 2011-13 trips/35 nights
Steve Lange is offline   Reply With Quote
Old 04-22-2012, 02:15 PM   #14
Loose Screws
Another concern we've been having is loose screws or stripped screws on our cabinits. We've had doors fall off, and cabinits open. Any fixes?
Old 04-23-2012, 12:16 PM   #15
I have a 2010 and the bedroom slide has a tooth broken off the gear box,plastic gears and the motor with gearbox is 479.00 not counting labor.
jack250 is offline   Reply With Quote
Old 04-23-2012, 03:53 PM   #16
Yes,remove wood screws that are striped or loose,dip wood tooth picks in wood glue and put in holes,fill it up with the tooth picks.let set over night.The next day trim off tooth picks even with the surface and place the screws back in the original location. There are a million loose screws in a R/V if you travel very much. Youroo!!
Old 05-20-2012, 02:20 PM   #17
Look'in To Ecapé's Avatar
We have a 2010 8314BSS and love it. This was the first year for the bedroom slide and does it make an difference. If you put too much weight under the bed the slide has trouble going out. We did have a screw back out under the living room slide which sctrached the under side of the slide but we had it repaired and now there are no problems. We did own a 2007 2604 which had the bolt on the drive break but all I did was to replace it with a Grade 5 and then had no trouble. Our trailer tows great and has so much room. The only thing I would change is the size of the Gray tank.
We did change the bedroom door to a sliding door but it looks like the 2012 model has the sliding door. I would hope we where part of this change because we sent the factory pictures and my plans.
GOOD LUCK WITH PURCHASE
I know this is an older thread but I'd love to see photos on your modification on the sliding door. We have a 2010 8315BSS and this is one of the only things that leaves us scratching our heads at the designers. We love the pass through bathroom but navigating those those two doors gets a bit dicey when someone is at the sink!
Thank you for sharing if you can! ~ Dawn
Roger & Dawn M.
2011 Rockwood Signature UltraLite 8315BSS
2004 Ford Excursion
Nights camped in 2011: 27
Nights camped in 2012: 34
Look'in To Ecapé is offline   Reply With Quote
