Old 09-16-2014, 09:33 AM   #1
Klbrown53's Avatar
Sink stain
Rockwood 8314 BSS less than a year old. Anyone else having issues with their kitchen sink staining? I suspect that they use the same sinks in a lot of models. We use Soft Scrub to clean it but it takes lots of elbow grease and does not stay clean long. Clean it and then spill a little coffee in it without wiping up and you have another big stain. Was wondering if there might be something to coat it in that would help. My first thought was car polish but probably not......Click image for larger version
Name:	ImageUploadedByForest River Forums1410877961.514028.jpg
Klbrown53 is offline   Reply With Quote
Old 09-16-2014, 10:00 AM   #2
Brewster McFrisk's Avatar
Use olive oil after cleaning works great
Brewster McFrisk is offline   Reply With Quote
Old 09-16-2014, 10:18 AM   #3
I've had that same problem on an identical sink. I nearly filled the sink with hot water and poured in a 1/4 cup of OXI clean and swished it around. Then let it set for about an hour or two and then drain and rinse.
OKI Marine is online now   Reply With Quote
Old 09-20-2014, 05:42 PM   #4
I use glass top stove cleaner.
DonCath25ds is offline   Reply With Quote
Old 09-20-2014, 06:58 PM   #5
nuisance's Avatar
At the factory they use (outside only, sprayed on a rag) brake cleaner and wiped the stain off of mine. i also have used Bon-ami cleanser works great and does not scratch.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
