Old 02-15-2015, 09:23 AM   #1
Thumbs up Sitting in closed slideout
I have heard several different opinions on this matter, is it okay to sit or lie down on bed in a slideout that is in the closed position?
Aggie Dad is offline   Reply With Quote
Old 02-15-2015, 09:28 AM   #2
Witch Doctor's Avatar
T I think it would be fine, the weak area when the slide is in is the edge don't step on that other then that IMO I think it would be fine.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-15-2015, 09:45 AM   #3
vinmaker's Avatar
Many people do this when they walmart camp or sleep in rest areas. I have not heard of any problems.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 02-15-2015, 09:52 AM   #4
fonzie's Avatar
X2, I do and no issue in 4 years.....
Fonzie
Old 02-15-2015, 09:56 AM   #5
If its a lippert slide then the strongest would be in the retracted position IMO. Think of it this way, the design would and should be, the most structural, in the retracted position, since the RV takes the most stress loads during flight. Just sayin'
Old 02-15-2015, 10:31 AM   #6
Platokidd's Avatar
Dont have a bed that slides-out. But I don't even walk on my super slideouts when closed.
My fridge slide is a laminated floor and the seems very strong. My living room / dinning room slide has way to much flex in the floor.
My 13 tracer superslide floor was splintering, from what I believe was from the dealer walking across the slide floor when closed when in for service.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-15-2015, 10:40 AM   #7
Sorry but am I missing something here, the floor material is the same as when open or closed , and when the slide is extended there isn't any added support under the slide so why can't you sit on the bed or walk on the floor of the slide, I do all the time in my 3051s
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 02-15-2015, 10:56 AM   #8
Platokidd's Avatar
Guess it all depends on the size , construction and design of your slide floor. A small slide in the bedroom could be safer to walk on then a super-slide. No way will I walk on my super-slides as the floor has no front side support when in the closed position.
nights of camping
Seasonal
Old 02-15-2015, 11:02 AM   #9
Originally Posted by Platokidd View Post
Guess it all depends on the construction and design of your slide floor. A small slide in the bedroom could be safer to walk on then a super-slide. No way will I walk on my super-slides as the floor has no front side support when in the closed position.
As I said I walk on mine and lay on the bed LOTS when closed and mine is a FULL !! wall slide ( can't get anymore super size than that) The OP never said what unit they are asking about so until then its hard to say if ok to sit/lay on bed as they asked.
2014 Forester 3051s
2012 Sonic toad
Old 02-15-2015, 05:12 PM   #10
Fulltime family RVer
It all depends on the slide. Longest story shortest- if it is a flush-floor slide (where it goes out and literally slides down into place for the slide's floor to be flush with the remainder of the camper's floor)- these floors lift up when retracting. The end of the wood isn't supported. These shouldn't be walked/be on unless the slide is fully extended.
Whereas a slide that isn't flush with the rest of the floor is supported if the slide is in. These are generally safe to walk/be on.
My camper has both. Unfortunately, to get to the fridge, the main slide has to be extended to avoid walking on it. I carry traffic collapsible cones (mostly for parking on the road at home), but I also use them to make sure someone doesn't hit it. Not sure they help as the slide is pretty obvious, but it makes me feel better.
slide, slide out
