Old 09-04-2014, 02:06 PM   #1
Slide fuse keeps blowing
I have a 2109S a 2013 model that keeps blowing the 30 amp fuse connected to the slide. It seems to happen when the slide is put out. Anybody have any thoughts on the reason?
Tom & Terri
2012 GMC Yukon
2013 Roockwood Mini Lite
Tomgky is offline   Reply With Quote
Old 09-04-2014, 02:31 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Happened with our all most every time. I installed while at the lake, three "Fuse Release's" 1-front slide, 1-rear slide, and 1-front pads. Now they just reset (2 second delay).
donanddona is offline   Reply With Quote
Old 09-04-2014, 02:42 PM   #3
I had a very similar problem it turned out to be the wire connection was loose causing the fuse to blow tightened up the wire connection problem solved. I usually look for wire connections or damaged wire when a fuse keeps blowing.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 09-04-2014, 03:06 PM   #4
Big Paul can you tell me where the loose wire was?
Tom & Terri
2012 GMC Yukon
Old 09-04-2014, 03:13 PM   #5
The loose wire on mine was on the down stream side of the big fuse or circuit breaker.
Old 09-04-2014, 03:17 PM   #6
B47
If a fuse keeps blowing its a sign that something in its circuit is defective such as a loose wire connection,corrosion, etc.. The fuse is just doing what it's supposed to do.
If you didn't determine the cause of the fuses always blowing and correct the problem,then you need to. Resettable fuses aren't the proper fix.
B47 is online now   Reply With Quote
fuse, slide
