Old 08-12-2010, 09:12 PM   #1
lbtex's Avatar
Slide Issue
Just spent a nice three days at Meridian State Park (Texas). Hot but pretty and nice nature trails if you hike early morning while still cool. Anyway, got home this afternoon and started to unload. Needed to open the slide since the 2607 bathroom door is blocked unless the slide is open. Hit the slide button and it started out then stopped and gears slipped. After much looking found that the motor for the slide is under the couch. It is (was) mounted to the fiberboard wall with four one inch long 1/4" lag bolts. All four were out. Matter of fact, still haven't found the fourth. The motor was binding against the couch above it and preventing the slide to move. Put the three back in, two of them were totally stripped out. One is holding somewhat but it was enough to be able to get the slide out and back in. Question is, what do I do about the lag bolts. Can't see what's behind the fiber board so don't know if I have room to put some wood behind or not. Will look in more detail tomorrow. Just wondered if anyone had encoutered such an issue.
2009 Rockwood 2607
2007 Nissan Titan
lbtex is offline   Reply With Quote
Old 08-12-2010, 09:19 PM   #2
milzat's Avatar
Someone posted about this problem. They made a repair, but don't remember what was done. If I find the post, I'll link it here.
milzat is offline   Reply With Quote
Old 08-12-2010, 09:24 PM   #3
milzat's Avatar
Found the post.
click here
Old 08-14-2010, 08:40 AM   #4
lbtex's Avatar
Tks Mike. Also searched this forum and found a similar example. Slide motor problem.... I'm hesitant to drill through outer shell but they may be the simplest way. I'll post fix when I decide and get it done.
2009 Rockwood 2607
2007 Nissan Titan
rockwood
