Old 07-26-2011, 04:47 PM   #1
lindy's Avatar
Slide level adjustment?
When I've gor the trl set up dead level side to side and front to rear, when I put a level on the table that's in the slide, the table slants toward the outside wall. Looking at the adjusters under the slide they're all the way down. Looks like I can adj the slide up about 2". Has anyone had to adj their slides? How tough is it, etc?
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 08-05-2011, 06:42 AM   #2
lindy, I have same problem with mine. I finally found out after taking pictures and emailing them to the Lipert rep. that my slider rails are RBW brand. RBW tells me no manual for them and take it to a dealer. I tried several adjustments got it level when slide was out but didn't line up when in position. So back to original adjustments. I have had no luck finding someone who knows anything about the RBW slider arms. I am taking it out to a dealer today. Ya dealers are as bad $$$ as frigin Doctors and Lawyers.
2005 Rockwood 8283SS 5er. 1999 Ford F250 Super Duty 7.3 Diesel, extended Cab. 2 dogs and a wife!
Gregad is offline   Reply With Quote
Old 08-08-2011, 10:16 AM   #3
mkollath's Avatar
i adjusted mine easily but like GREGAD said, i got it level but when it slid in, it was NOT lined up properly. it looked like they dropped one end a bit to "fit" the hole..so, i set it back the way it was...
Mark and Connie
2008 3001W Windjammer
2005 Tahoe Z71, 5.3L
Equal-i-zer WD
mkollath is offline   Reply With Quote
Old 08-08-2011, 10:22 AM   #4
mkollath's Avatar
i found a link for the manual on this forum..go to the search and type "slide our adjustment" and there are several feeds from others that contain manuals, depends on your brand
Mark and Connie
Equal-i-zer WD
Old 08-08-2011, 11:05 AM   #5
Location: Canandaigua,New York (The heart of the Finger Lakes)
The slides are tilted down so the water drains away from the seals on the camper. if you have it level you risk the water pooling and leaking into the camper. If you have slide toppers then its a different story. On the line at the factory they don't know which campers are getting slide toppers, so there all set with tilt!
David & Annamarie & 2-Pugs (Fatty and Harley)
2011 Rockwood Windjammer 3065
2011 Ford F-250 6.2- V8
2011 Hensley Arrow "NO-SWAY" Hitch
BigRed is offline   Reply With Quote
Old 08-08-2011, 12:16 PM   #6
My problem is mine slopes way down. When it is open, the top is tight against the trailer side but the bottom is out at least 2 inches and daylight, bugs ect. can get in. Repair guy not sure about it either. I had 4 different dealers tell me 4 different things. Right now it is at a dealer whom just called and said, ????? They don't know.
I have a RBW slider, not a Lipert. Al-Ko now owns RBW and they tell me there are no manuals to adjust it. Ya Right!
ANYBODY Knows about RBW slide adjustments, I am desperate.
Old 08-08-2011, 03:02 PM   #7
Woooo Hooooo! Got my slider adjusted. Now it drops level with the floor like it should and seals all the way around. There is a long threaded rod inside the arms that adjusts the whole assembly outwards. Found out there was no secure pins in them to keep them from vibrating back in. But now there is and room is level. The roof line tilts to allow water run off.
