Old 07-30-2013, 06:45 PM   #21
cantho's Avatar
Just back the screws out a little and you have all the room you need. The more you look the more you will discover, take some pics with notes for next years use. Make sure you close all the storage and bathroom door before the slide is brought.
cantho is offline   Reply With Quote
Old 07-30-2013, 07:05 PM   #22
Do you have a link to the video. Might be good to save in case an issue arises
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
https://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 07-30-2013, 07:08 PM   #23
Another thing I did was climbed underneath it and tied up some of the words better and took a wire brush and painted a few rust spots I found on some welds
2013 Ram 1500 (5.7)
Old 07-30-2013, 07:11 PM   #24
raspivey's Avatar
If you follow that link to YouTube, it has a few more videos of this system.
Old 07-31-2013, 08:14 AM   #25
Also go to the Lippert/Schwinteks web site for downloadable owners manuals which my dealer told me weren't available.
Ole Buzzard is offline   Reply With Quote
Old 08-05-2013, 12:17 PM   #26
lswartz's Avatar
Originally Posted by fanrgs View Post
I have been traveling over some pretty rough roads in Canada and Alaska lately (we are now on the Kenai Peninsula) in my 16 month-old 2109S. Yesterday my slide motor bolts came loose from the wall and the motor stopped working. When I checked under my sofa, the motor is just screwed into the trailer wall, not into the aluminum frame, so the screws stripped the hole when they pulled out. The motor puts out so much torque that it also blew the slide fuse when it broke loose from the wall. My emergency repair today has been to put the screws back in with Gorilla Glue on the threads and a stack of books under the motor to keep it level. Then I replaced the 30 amp fuse tha I searched all over for. It is located in a fuse holder attached to wiring beneath the frame of the trailer below the left side of the basement, not in the basement where it would be protected from weather. It is labeled "Not more than 30A." Fortunately, I carry a big supply of 15A and 30A fuses, so replacement was easy once I found the fuse.
Lesson learned and advice for others: watch the attachment points for your Rockwood slide motors, as they may be screwed into some pretty flimsy material.
I just checked mine today, 1 top bolt was out completely & the other 3 were loose. Tightened them up & opened the slide, closed it & they are loose again. I can't get it to the dealer until September 5th . I guess they are busy. I'll try a wood block for the motor to keep it level & hope for the best. I need it to work 1 more time for a trip to Acadia, ME on the 19th.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 08-07-2013, 03:25 PM   #27
Nick1122's Avatar
raspivey, where did you find the troubleshooting guide for the slide? I'd like to view it.
Nick1122 is offline   Reply With Quote
Old 08-07-2013, 03:34 PM   #28
Nick1122's Avatar
Oh, I just noticed that you already posted it.
The problem I'm having is that when the slide is extended it moves up and down when you sit down or get up. It seems like it is not fully seated or something.
Does anyone have a suggestion?
Old 08-07-2013, 04:41 PM   #29
raspivey's Avatar
It shouldn't move noticeably, at least mine doesn't. Make sure it's run all the way out (stops on it's own) before you let go of the switch. Other than that, all I can suggest is to take it in and look at maybe having it adjusted.
Old 08-07-2013, 06:45 PM   #30
Nick1122's Avatar
It didnt start doing it until I sprayed some lubricant on the bottom gears of the slide.
I run it out until it starts clicking.
Old 04-03-2015, 06:48 PM   #31
Found the slide fuse under the frame
After reading all the comments on the 2109 slide, I crawled under the trailer and found the 30 amp in-line fuse. Sure enough it sits there all exposed to rain and road slop. Forest River should have put this in the storage compartment. As a hopeful fix, I cut the thumb off one of my nitrile gloves that I use for sewer dumping. Stretched the thumb and put it over the fuse. Hopefully this keeps the water out. So far so good.
dannyeager
2109s Mini-Lite
2008 Ford F-150
dannyeager is offline   Reply With Quote
