Old 04-10-2011, 11:29 AM   #1
Slide motor died where does the maual crank go
I have a rockwood ultra light 2304s ,2011.I was doing some cleaning today went to put slide in it bound up and kept blowing fuses.I have a manual krank i can not find anywhere to put it to close the slide.Anyway took the motor out and the gears are gone ive used this trailer about 5 times.My warranty ran out 3 weeks ago great.Will be calling forest river tomorrow.It has a enclosed underbelly.
4runner is offline   Reply With Quote
Old 04-10-2011, 12:52 PM   #2
sherdep's Avatar
Cant help you with your question other then to look in the manual to see if it shows location and that blows about the slide gears -
Silly question is did you not buy the 2nd year warranty for the $150?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-10-2011, 10:50 PM   #3
FarmerMT's Avatar
You might want to go to the search bar and type in "slide out manual operation". There are several old forums on this topic. It seams the slides manufacturer has a lot to do with the fix. On some slides the manual crank goes into a hole on the opposite side of the trailer from the slide, some are a small bolt on the back of the motor accessed by a hatch in the underbelly. I saw some needed you to create a hatch in the underbelly.
Phil, Michelle, Logan and Wyatt
2006 Dodge 2500 Heavy Duty 5.7 Hemi
2012 Rockwood 8312ss
FarmerMT is offline   Reply With Quote
Old 04-11-2011, 05:39 AM   #4
Wanna Be Camper
SaskCampers's Avatar
There will be a hole in the body on the other side of the trailer inline with the sllide motor. That is where you insert the crank handle. It will be quite low on the side of the trailer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 04-11-2011, 06:43 AM   #5
manual operation
I found it its on the motor itself but it would'nt work be cause the gears are toast.
