Slide motor problem....
Hi all,
I have a Rockwood 2701ss that thankfully has been relatively trouble free, that is until last weekend. While pulling the slide in to pack up I noticed a strange sound. Almost as if something was caught in the track. I kept retracting the slide and it finally came in an I thought all was ok.
On a whim, I decided to check out the motor under the couch, and to my dismay, the motor had pulled completely off the wall! I secured the slide with the slide locks and proceeded home.
The next day I decided to take a look at the motor again to figure out if the bolts had just backed themselves out, or if they snapped, or what. Turns out the bolts are just large wood bolts that screw into the sidewall of the camper. I tried to relocate the motor slightly off from the original mount point and after one use the motor already started pulling away from the wall.
Long story short, has anyone else had this happen to them? If so, how did you repair it? My solution for now is to bolt the motor to a piece of 18"-24" plywood and then attach that to the wall with about 16 screws to help distribute the torque. ANy thoughts?
Thanks,
Brian
2008 Rockwood 2701ss
2008 F-250 Lariat 4X4 6.4L PSD
Reese DC WD hitch
