Old 09-03-2012, 02:38 PM   #1
wagon52's Avatar
Slide on 8312SS won't slide out
Went out to get something out of the back of the camper today. Needed to put the slides out to get to it. The rear slide went right out but the front just made a clicking noise and no movement. Thought that maybe the battery didn't have enough juice to do the task, so I plugged it in to shore power and tried again. No dice. Anyone else have this problem or a possible fix? Either way I'm gonna call the dealer tomorrow.
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone)
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
wagon52 is offline   Reply With Quote
Old 09-03-2012, 04:06 PM   #2
KyDan's Avatar
Do you have a battery disconnect switch?? IF you leave your battery connected it will
run down in just a few days or a couple weeks. IF your battery is very low it won't run the slide even if it's plugged in. Leave it plugged in for a couple hours and try again.
If it works after a while you definitely need a battery disconnect switch so you aren't killing your battery every time you store the trailer. It won't last long that way.
All trailers should come with a disconnect switch. Most don't and you have to add it yourself. There are many threads here about them. Just search the site for battery switch and you'll find plenty of discussion.
Also read the FAQ here-- Why is my new battery dead?
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-03-2012, 04:32 PM   #3
wagon52's Avatar
Thanks for the info. I will check when I get home this evening since I left it plugged in. Yes mine has a cut off switch and it has been off since my last trip.
Old 09-03-2012, 10:39 PM   #4
wagon52's Avatar
Still doesn't work after being plugged in for 10 hours.
Old 09-04-2012, 06:55 AM   #5
KyDan's Avatar
Bummer!! Sounds like it's time to call the dealer.
Please let us know what you find out. We're always glad to hear
"the rest of the story".
Good Luck!
Old 09-04-2012, 11:58 AM   #6
wagon52's Avatar
Well my saga with the best dealer service continues. Called my dealer today and was told they couldn't even look at it until October 9th. Told them I had a trip planned for September 21st and my slideout wouldn't work and the trailer is only 4 months old. I was told that they couldn't do anything because the RV show was coming up and all their technicians are going to be tied up with that. What a crock of sh!!!!! I mean I don't expect them to drop everything but c'mon!
Old 09-04-2012, 12:09 PM   #7
fonzie's Avatar
You could try to use manual handle to move as maybe just stuck. If it moves then try electric again??
Fonzie
Old 09-04-2012, 12:12 PM   #8
Road-King's Avatar
Is your trailer level? The clicking sound may be your clutch on the slide mechanization. If not level it may be binding... Just a guess.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-04-2012, 12:14 PM   #9
wagon52's Avatar
It's not completely level but it's parked the same place it's always been when not in use and have had no problems with it before. I'll try it though.
Old 09-04-2012, 12:19 PM   #10
wagon52's Avatar
Would do that but I don't see a crank to do it manually. All I see is a crank to manually put down the stabilizers. That's my own dumb fault though.
8312ss
