Old 02-06-2015, 12:01 PM   #1
david345's Avatar
Slide out help
I have a 2012 rockwood 2608 ss that I just bought. This one has a wardrobe slide in the bedroom and a large slide inn kitchen living area. They are both electric but in case of power failure how do I extend and retract the wardrobe slide. I found the place for the large slide but I just don't see how the smaller one works. Thanks for any advise.
David
david345 is offline   Reply With Quote
Old 02-06-2015, 12:28 PM   #2
fonzie's Avatar
If your unit is a 2608WS which is for "wardrobe slide" then you probably have the schwintek system....
This is one video but do a search above and you will get more info on forum....
Fonzie
Old 02-06-2015, 12:57 PM   #3
david345's Avatar
Thanks. I hope I don't have to do that
Old 02-08-2015, 10:49 PM   #4
i also saw about those that each time you run the schwintek slide in or out hold the switch down for 3-5 sec to let the motors sync back! Might help prevent a problem.
firedaniel is offline   Reply With Quote
slide, slide out
