Old 04-04-2017, 09:11 AM   #1
Lookin2camp's Avatar
Slide out lubricant
For the 8312 Rockwood what, or is any lubricant recommend for the slides.
White lithium food style grease , silicone style or a blaster.
[emoji1308]
Lookin2camp is offline   Reply With Quote
Old 04-04-2017, 09:15 AM   #2
Insert witty title here
You want a dry lubricant so dirt and debris doesn't stick to it.
I use this stuff:
https://www.amazon.com/Protect-All-4...lide+lubricant
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 04-04-2017, 09:17 AM   #3
Do not use any style spray greases unless your slide particularly calls for it. (not seen many)
Always use a dry lube so dirt and road debris doesn't stick and contaminate the slide mechanism.
Here's what I've used for several years.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 04-04-2017, 11:16 AM   #4
McRabbet's Avatar
The lubricant recommended by the OEM for the slides on my TT is CRC Power Lube with PFTE, available on Amazon.com.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
McRabbet is offline   Reply With Quote
Old 04-04-2017, 01:07 PM   #5
NMWildcat's Avatar
X2. And it's cheaper than most brands that specify 'slide lube' and is the same stuff.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 04-05-2017, 05:17 PM   #6
Enjoying Life
X3 .. Run it in and out a few times to make sure it is well distributed
TeachTexas is offline   Reply With Quote
slide, slide out
