Old 03-30-2015, 09:07 PM   #1
Slide out not working
The is no movement or noise when I push the slide out button in my 2014 Rockwood 2104 Ultra Lite. From reading posts it seems like it is the fuse but where do I find the fuse?
Lindy1951 is offline   Reply With Quote
Old 03-30-2015, 09:32 PM   #2
raspivey's Avatar
Check the motor controller first and see what, if any, codes are flashing. It's located in the front wall of the trailer to the left of the water pump.
Old 03-31-2015, 07:02 AM   #3
mrmichael's Avatar
fuse
There should be a 30A fuse in a holder underneath where the A frame meets the body of the trailer. My fuse holder is red but not sure they are all that color
Other Motorhome
2013 F-150 Eco-Boost V6
mrmichael is offline   Reply With Quote
Old 03-31-2015, 07:25 AM   #4
if you find the issue please post. i have the same model and it would be something for me to look for if i have the same issue
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 03-31-2015, 02:10 PM   #5
Blaster 84's Avatar
If yours is wired similar to fifth wheels it may be that a wire separated. The wire runs inside the tube that travels back and forth and are not always spliced very well. You can only find it by dropping the pan and gently pulling on the wire. Mine was a heavy lamp cord type wire that had separated from its splice due to friction when the slide moved.
2013 F150 XLT, SuperCab, Ecoboost; Rockwood 8285WS
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Blaster 84 is offline   Reply With Quote
Old 04-10-2015, 09:54 PM   #6
I had the same issue on my 2502 and had to take it to the dealer to show me. The fuse is under the vehicle on the front driver side. It is about a foot behind where the cabin starts. Go figure!!!
Riders on the Storm
2014 Mini Lite 2502
2014 Ford F-250 Diesel
montereydiver is offline   Reply With Quote
Old 04-11-2015, 11:23 AM   #7
I have had my 2504 for a little over a month and have already had to replace the fuse twice. It is about a foot in front of the box on the drivers side under the frame.
Skip 63 is offline   Reply With Quote
slide, slide out
