Forest River Forums
Sunline User Photos
Old 07-24-2011, 08:56 AM   #21
Nights Camped in 2010 - 2
It sounds like it. Mine broke 5 days before our trip to Pine Hurst last year for Thanksgiving. We did not go because the dealer had the TT. It took me calling the owner to get it back In a reasonable amount of time. Have you tried to manually move the slide? If the motor leakage is broke, yon still might be able to crank it out and in manually. Maybe not, but wroth a shot. I will check out the campground. Sounds nice. Send me a private message and I will give u my number. Be more then glad to help out if I can. Thanks, George
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 07-24-2011, 12:32 PM   #22
Hi George,
My husband (Wayne) finally got through to service dept manager at Beckley's yesterday (that is where we bought it). He said to call in the morning and he will see if he can fit us in. Wayne went to triangle yesterday to buy the T-crank we need to manually slide it out and the one they sold him was 1 inch too short. He got so frustrated he but the underbelly back on and is basically going to wait until Beckleys can fix it. Even if we get it in tomorrow, they will probably need to order parts so I am sure it will not be fixed in time for our trip. We are too scared to manually crank in out in PA for fear we might not get it back in. I think we are just going to tough it out. I will let you know how the repair works out. Thanks again and happy camping! Pati
phoyt916 is offline   Reply With Quote
Old 07-24-2011, 02:39 PM   #23
Understand. Hope Beckeley's come through for you. Enjoy your trip. If I can be of help, just drop me an note. Good luck, geoege
George Kelly
Old 07-24-2011, 04:33 PM   #24
I did discuss this with forrest river. It originally was supposed to be grade 8. You can tell grade 8 by the gold color or the markings on the head of the bolt. I got mine at fasten all. I put a flat washer on both sides and a self locking nut tightened well. No problems since replacing all mine.
Bill And Theresa Perry, At Lake Gaston
2008 Rockwood Ultra Light 8313SS(modified)
2007 GMC Sierra SEL 5.3 and 3.73
bill and theresa is offline   Reply With Quote
Old 07-24-2011, 07:00 PM   #25
Bill_C's Avatar
Don't go by colour to determine a bolt grade. ( I have gold coloured grade 4 bolts in my shop). Count the raised lines on the top of the bolt and add 2. 6 raised marks around the head, add 2, makes a grade 8 bolt.
This is the American Standards of bolt grading and is the only reliable way to determine a bolt grade.
DRINK COFFEE--do stupid things faster and with more energy !
Bill_C is offline   Reply With Quote
Old 07-26-2011, 09:04 AM   #26
Slide Fixed!!
Hello. We have some great news that some of you long-time campers might find amusing. Our slide is working great. It turns out that our battery was bad and although we had the camper hooked to our house it still depends on the battery to operate. I am very grateful to Beckleys Camping Center for fitting us in!
I also give glory to God because a storm caused a power outage and let us know the battery was bad when it didn't hold a charge overnight when the house circuit tripped. That put Beckleys on the right path to diagnosing the problem! Thank you Lord for answering our prayers and allowing us to go camping on 08/02 with a working slide!
Old 10-15-2011, 01:26 PM   #27
I just recently bought a '08 28BHSS, and was told to open the slide entill I hear the ratcheting noise (same for fully in) and the rear bolt sheared off after about the 8th time opening the slide.. I was wondering if this is the recomended way to fully open and close the slide, and if so is there an adjustement for the ratchet to keep it from over torquing the mecanism and poping the bolts?
Mario 28bhss is offline   Reply With Quote
Old 10-15-2011, 01:46 PM   #28
I never leave mine on til I hear ratcheting. I come in or out til it is sealed and quit. DW usually does this and I am outside and tell her when to stop.
Old 10-15-2011, 02:48 PM   #29
ARLO
broken bolt
The bolt that FR used may have been what is called a shear bolt. It is made of a softer material that will allow it to shear before a malfunction damages the system. These are commonly used on outboard props, snowblower augers etc.. I do not know if this the case in this application but it sounds like a plausable answer. You may want to check with your RV terch.
Originally Posted by TWO4THEROAD View Post
Actually, I just had the same problem with MY slideout. It made the same noise and stopped working on 1 side, I crawled under the slide and found that the bolt that hold the shaft from the gear to the motor had sheared off, so the motor was only turning one side of the slide. I replaced the bolt with a "hardened" bolt. for some reason FR put a regular steel bolt not hardened so it sheared off. Just be sure that the slide in even on both sides before replacing the bolt. This seemed to solve the problem for now. Good luck
rlocicero is offline   Reply With Quote
Old 10-15-2011, 03:15 PM   #30
Thanks for the reply,
We can hardly wait for next season to realy try out the virtues of a fifth wheel ( our previous RV was a fleetwood travel trailer)
rockwood
Close [X]
