Old 08-08-2016, 08:33 AM   #1
Slide out sticking at top
When moving the slide out the top sticks in place until i give it a slight push. Only happens on the outbound. Any ideas why? This is a 2016 Rockwood Mini-lite 2109s.
Spanko is offline   Reply With Quote
Old 08-08-2016, 11:32 AM   #2
Moderators' Assistant
bikendan's Avatar
This happened to us.
But it was because we camped in wooded campgrounds.
The tree residue got on the seals and side of trailer and acted like glue.
Since we got a slide topper, it's never happened again.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 08-08-2016, 11:40 AM   #3
Thank you. This trailer has only been out twice. Plus we do have the slide out awning. Am going to lubricate slide mechanisms with Liquid Wrench RV Dry Lubricant to see if that helps. Now I just have to figure out where they are. ;o)
Old 08-08-2016, 11:41 AM   #4
Head Rambler
Have you cleaned and lubed the seals?
It could be as Dan noted, something causing the seals to stick.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-08-2016, 12:58 PM   #5
Yes it has been pretty hot and trailer has been in storage unti this past week. Cleaned and applied silicone to the seals top and sides, and cleaned and applied dry lube to gear runner on bottom. Hopefully that helps.
Thank you all for your suggestions.
Old 08-08-2016, 01:43 PM   #6
Mine was sticking, found some glue thye residue on both upper corners, cleaned off and applied wax to TT in those areas and put silicone spray on gooey area.
pdqparalegal1 is offline   Reply With Quote
Old 08-08-2016, 02:20 PM   #7
Clean the seals with seal cleaner and conditioner. Spray it on, let it foam up, then wipe with an old rag. Also, baby powder applied lightly along the seals tends to keep everything from sticking to them. When the seals are dry, simply shake a little into a dry rag, toss it up and down a few times to get the powder dispersed through the rag, and then wipe it along the seals. No more sticking.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat 4X4 6.4 Diesel
61 nights in 2016
10 nights so far in 2017
ben31 is offline   Reply With Quote
Old 08-14-2016, 10:44 AM   #8
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by ben31 View Post
... baby powder applied lightly along the seals tends to keep everything from sticking to them. When the seals are dry, simply shake a little into a dry rag, toss it up and down a few times to get the powder dispersed through the rag, and then wipe it along the seals. No more sticking.
Good ol' standby. Inexpensive and very effective, use it myself. Learned the baby powder trick as an auto mechanic working to make windows roll up and down mo' easy.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
slide, slide out
