Old 08-06-2014, 05:23 AM   #1
slide out switch
can you replace the slide out switch with any slide switch, or is the switch motor specific? thanks ric
ric306 is offline   Reply With Quote
Old 08-06-2014, 08:29 AM   #2
Dave_Monica's Avatar
I wouldn't see that the switch would make any difference at all as long as the wiring connections are the same on the back. I think the wiring should all be the same...power to the center then reversed polarity on each end for the slide motor to run forward or reverse.
Dave
slide, slide out
