Old 09-20-2015, 02:40 PM   #1
Slide out toper adjustment???
Is there a way to tighten a slide out cover so it will not hold water???I have a Rockwood Signature 8327ss (sofa (longest toper) is holding water??
fkwalter is offline   Reply With Quote
Old 09-20-2015, 02:46 PM   #2
fonzie's Avatar
maybe this will help......
Slide Awning adjustment - 2012 337DS
Fonzie
Old 09-20-2015, 02:58 PM   #3
Oklahoma Proud
MillerTime's Avatar
You can add an extra wrap on the tube if you take the material loose from camper. Or you can take the rivets out of the end cap and tighten the spring one revolution and then put a screw back in or a new rivet. Probably need an extra guy or two to help you either way.
We've had the same problem on our main slide, slide topper.
Old 09-26-2015, 08:32 PM   #4
Dabmeb's Avatar
Very cheap fix for this is two cheap inflatable air mattresses. Slide them in on top of the slide head to head and the water will run off and also keep the topper from flapping in strong winds
Dabmeb is offline   Reply With Quote
slide, slide out
