Old 03-13-2015, 01:33 PM   #1
Slide out trouble 2104S
Can not locate manual crank out nut on Rockwood 2104S.
Not working either. Fuse is good...Not sure what is wrong.
Please suggest possible problem.
sdev is offline   Reply With Quote
Old 03-13-2015, 02:02 PM   #2
fonzie's Avatar
I believe you have a Schwintek slide system, if it is the case, then you don't have a manual crank. Here is manual.....
Fonzie
Old 03-14-2015, 09:44 AM   #3
Newbie
Probably too late, but the crank is on the other side from the slide, right above the two axles on the frame.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
okiecowboy is offline   Reply With Quote
Old 03-14-2015, 09:59 AM   #4
fonzie's Avatar
If that is the system you have then it would be mostly this manual....sdev, what year is your unit?
Fonzie
Old 03-14-2015, 10:22 AM   #5
2015
Old 03-14-2015, 10:26 AM   #6
Platokidd's Avatar
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-14-2015, 10:28 AM   #7
fonzie's Avatar
Originally Posted by sdev View Post
2015
I'm asking at it seems the 2014 has the Schwintek and the 2015 has the undermount electric slide. So which one do you have?
Fonzie
Old 03-14-2015, 10:31 AM   #8
Platokidd's Avatar
Originally Posted by fonzie View Post
I'm asking at it seems the 2014 has the Schwintek and the 2015 has the undermount electric slide. So which do you have?
Its a good idea to have the unit you have in your sigline
nights of camping
Seasonal
Old 03-14-2015, 10:36 AM   #9
Platokidd's Avatar
on a 2015 you may have to drop or open the underbelly cover. I think the manual crank out would be on the door side.
nights of camping
Seasonal
Old 03-14-2015, 12:00 PM   #10
Newbie
Mine is a 2015, nothing to open. Located on the door side opposite the slide, right above the two axles in the frame. Should be a crank handle somewhere in the trailer to use on it.
2015 Rockwood 2104S
210, slide, slide out
