Old 05-12-2014, 02:52 PM   #11
TigerPride
cajunrvr's Avatar
Mark that was the same problem for me. Thanks old coot will try that as soon as able
cajunrvr is offline   Reply With Quote
Old 05-12-2014, 07:51 PM   #12
I had the same issue on a previous trailer. Also on the super slide. I always thought it just didn't have enough slope to allow run off. I did cut pieces of foam to put under the topper to help. It did but was just a pain putting it in and taking it out each time. My current trailer has the same topper and does a great job with run off. I have more of an issue trying to clean the underside of the darn thing.
reinbeauke is offline   Reply With Quote
Old 05-13-2014, 06:43 PM   #13
TigerPride
cajunrvr's Avatar
Old coot I adjusted the slide topper and now it is tight. Apparently there was more water up there than I thought. When I seen it sagging I would take a brush with long Handel and push up slightly to drain the water. I guess all water didn't run off. What I'm seeing now is the topper is sagging in the middle. Being that all is brand new do u think it will tighten back up or am I screwed lol
Old 05-13-2014, 08:39 PM   #14
Mine tightened up over time in the sun. I thought I was going to have to replace the material, but so far, so good. Just leave the slide out and let old mother nature do her magic.
Old 05-14-2014, 05:01 AM   #15
TigerPride
cajunrvr's Avatar
Thanks buddy you have been a lot of help!!!👍
slide
