Old 09-25-2017, 06:37 AM   #1
Slide weather proof
Hi are the electric slides on rv weather proof when out? Can you fit small retractable awnings to them? Our there covers for these?
bish is offline   Reply With Quote
Old 09-25-2017, 06:52 AM   #2
Jaz 1960's Avatar
yes,they make slider awnings,get your make and model and search the web or call your dealer.
Jaz 1960 is offline   Reply With Quote
Old 09-25-2017, 07:01 AM   #3
ben31's Avatar
They are normally called slide toppers. They work very well at keeping garbage from coming in, when you pull in the slide. If you don't get them, you will need to sweep off, blow off, remove the water, etc. of the slides, prior to pulling them in. It also protects the slide out roof and keeps it a little cooler in the summer.
You will have people tell you they aren't worth it, all it takes is a little time, etc. To me, and a vast number of other people, it is worth it. A couple less items I need to remember to do, when hitting the road.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
roo, roof, slide
