Old 11-30-2015, 03:29 PM   #1
slideout drive Rockwood 2006 model 8283
Does anyone have an electric drive as shown in the attached picture. Basically electric motor driving a gearbox/clutch which drives a differential gearbox which drives the rack gears for the slide. I am wondering about what maintenance should be done to the unit ? Looks like there is a plug on the differential gearbox. Not sure if there is suppose to be gear oil in the box or not. Can't find the supplier on the internet as they look like they have been bought out. I like doing preventative maintenance rather than being surprised with a breakdown during a trip.
johnnyslick is offline   Reply With Quote
Old 11-30-2015, 07:12 PM   #2
No pic.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 12-01-2015, 08:32 AM   #3
Sorry first time posting pic
I thought I added pic the first time. See if they are attached this time.
ID:	95343   Click image for larger version
ID:	95344   Click image for larger version
Old 12-01-2015, 08:45 AM   #4
fonzie's Avatar
Could be Lippert electric slide mechanism......
Fonzie
Old 12-01-2015, 09:16 AM   #5
Witch Doctor's Avatar
The only maintenance is to spray your slide tooth mech with some dry lube, that's it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-01-2015, 09:42 AM   #6
Yep.
The drive itself is an M tec. M tec was bought by Drew Industries / Lippert in 2011.
The motor and transmission is a Thomson Saginaw model. Lippert may hold control of the design of it also nowdays, although the case construction is now plastic.
Mr Havercamp is offline   Reply With Quote
Old 12-01-2015, 10:26 AM   #7
M tech drive
The M Tec drive is my interest. It looks like it might hold some sort of gear oil. Has anyone ever tried to check the level or changed the oil ? My unit is approaching 10 years old and was just wondering if anyone has ever had problems with the M tech drive unit ?
Old 12-01-2015, 10:35 AM   #8
The one thing I'm certain of is that it is probably a much better constructed piece than you're going to get today from anyone.
Why not call or send an email to Lippert Components. Despite some of the things they manufacture being total junk I have had some good experiences with their engineering department on a couple of issues. They might be able to send you the original Mtec documentation.
You could always pull that unit off and dissect it, which is probably what I would do
Old 12-01-2015, 10:55 AM   #9
lippert is good to despite what some members think, they will help as stated above. If you do not see a zerk fitting nothing needs to be done....
Coachmen M/H
Concord
2018 / 300 DSC
rockwood, slide, modifications, slide out
