Old 08-31-2011, 01:26 PM   #1
Slideout problem
Hi, I have Rockwood model 8314ss and the slideout does not go all the way out at the bottom. It lacks 2 to 3 inches from sealing at the bottom when the rachet starts its clicking sound indicating that it is as far as it is going. Is there a adjustment that I can make and is there a way to manually crank it out? Thanks in advance.w
Dan & Donna
Dan-Donna is offline   Reply With Quote
Old 08-31-2011, 01:36 PM   #2
Try this;
http://www.lci1.com/OwnersManuals/Sl...ideout-Web.pdf
Old 08-31-2011, 01:36 PM   #3
I have the 8313 and never had that problem but you should have a rank handle that fits near the motor to jack it out or in.Of course if a bolt is sheared the crank does nothing. your does not sound ike a sheared bolt so the crank should work. good luck
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
