Old 09-09-2013, 06:44 PM   #1
Paul & Sheri
pwb01's Avatar
Slow Leak in the Air Mattress
Worked fine until recently. I find that a small amount of air is leaking from the manual valve. (tested under water). The rubber flapper holds only when there's pressure inside and it's not sealing completely now when full. I've cycled the lever back and forth and don't know what else I can do for a good seal.
suggestions?
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 09-09-2013, 07:30 PM   #2
Mine has a screw-on ring around it that I needed to tighten. (I have no idea if yours might be the same.)
Old 09-09-2013, 07:34 PM   #3
Camping Buddys's Avatar
X2
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 09-10-2013, 07:18 PM   #4
Paul & Sheri
pwb01's Avatar
I can't tighten the cap enough and still see bubbles. The flapper inside should seal and isn't. Maybe a little vasoline on the threads, I'll try that. Thanks.
2006 Sunline T1950
2004 T@B T-16
Old 10-14-2013, 07:51 PM   #5
Maron
Send a message via Yahoo to Maron
Having owned sofa stores that have sold many sleepers with air mattresses, find out who the bladder manufacturer is. They will replace it for free or at most $20. Most of them are made by Leggett & Platt down in Carthage Mo. There should be a manufacturer number on the bladder.
Maron is offline   Reply With Quote
Old 10-15-2013, 07:58 PM   #6
Paul & Sheri
pwb01's Avatar
Just may do that. I did get it replaced last year through the RV dealer when it went flat over night every time. Now it may or may not lose some air overnight. puzzling.
2006 Sunline T1950
2004 T@B T-16
air mattress, leak
